what software/freeware do i need to convert any type of video into a flash movie file?
Results 1 to 10 of 10
As its a proprietary format...I would expect that you need the actual flash software.
Have you looked in the HOW TO / CONVERT section?Google is your Friend -
yes, i've looked into that. and searched google... all i see is flash into video and no video to flash...
so tell me what software do i need? -
Sorenson Squeeze has this capability. But, the trial version leaves a watermark on the final video.
thanks... downloaded the trial and works great. now i just need to find it at my local store... if not then i guess i have to order it...
Glad it worked. However, I doubt that this will be available in stores (or atleast I have not seen it yet)
or try Riva FLV Encoder....and avidemux =avidemux2(clickable link.....
LINK DELETED is a easy-to-use yet powerful software to convert your video to flash, then you get the flash(swf, flv) on your site. I suggest you try it.
and there is a good news for you, DELETED will be depreciated because Christmas day.
Good luck!
LINK DELETED
No SPAM. Goodbye .
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator redwudz
How to convert a Flash video (*.SWF) to a Movie (*.AVI)
By potatosalad in forum User guidesReplies: 27Last Post: 3rd Jun 2015, 10:02 -
I could not convert Flash file to Video I try everything
By designbuyers in forum Newbie / General discussionsReplies: 16Last Post: 28th Oct 2010, 07:42 -
how to convert avi to flash video 4!!!
By dsl123 in forum Video ConversionReplies: 1Last Post: 18th Dec 2009, 11:09
