  1. Member jetfan's Avatar
    Mar 2003
    new york
    Hello, I was wondering if there is an easy way to make a disc auto repeat. I did a search but really didn't find what I was looking for. What I am trying to do is this: I like to use Shrink in reauthor mode, put together a bunch of small clips (childrens shows actually, like Thomas or Bob the Builder) so I have no menus, ads, etc... I want he disc to repeat itself when it reaches the end, right now they just stop, the originals will replay themselves indefinitly, and that's what I want. If this is impossible with shrink, I also have DVD2One. Otherwise any suggestions would be greatly appreciated. Thanks in advance.
  2. Member abc-123's Avatar
    Aug 2005
    North America
    I don't use any of the programs you mentioned so I can't give you specific advice, but in theory it sounds to me like you need to make a dummy menu. Have the last clip automatically go to the menu and have the menu automatically play the beginning of the movie. If it's just a black menu page and set to execute right away, you'd never hardly see it.
    Even your first play could go to that menu since it would auto execute.
    Either that or use the repeat button on your dvd player?
    This would be easy to set up in Dvdlab pro. (free trial available)
  3. Member jetfan's Avatar
    Mar 2003
    new york
    Thank you Borax, I will try it tomorrow.
