When burning .avi files to DVD+R or DVD+RW using Nero Vision Express 3, I sometimes get a "Disk Error" message on my DVD player. My player is a brand new Sony DVD-HD that has the ability to play all types of disks.
This doesn't happen on all burns. Most play fine.
Are there different types of .avi files? Any ideas?
Most set top DVD players will not read AVI's. Your sony might be able to play all types of discs, but might not be able to play avi files.
Bodyslide
I burn .avi files to a DVD with Nero Vision Express 3 which encodes the avi and creates a folder named VIDEO_TS on the disk. This folder contains various files with VTS_******.*** files.
I'm not trying to play the avi file in my player.
I sometimes get DVDs that will not play giving me the Disk Error message. -
Disk Error normally means the player doesn't like that brand of media. Can you try a different brand to see if that solves the problem? My brother has a Sony DVD player and it lonly likes a few brands of media, TY and Ritek.
You could also be getting bad burns with your DVD burner for any number of reasons. You can verify the discs with DVDInfopro.
Google is your Friend
Quality of burned disk question
By 81artmonk in forum Authoring (VCD/SVCD)Replies: 0Last Post: 21st Dec 2010, 20:26 -
Dvd recorder won't played burned disk
By 81artmonk in forum DVD & Blu-ray RecordersReplies: 13Last Post: 14th Aug 2010, 05:40 -
Compatibility of burned DVDs
By cool612 in forum Newbie / General discussionsReplies: 3Last Post: 7th Jun 2010, 22:16 -
do burned dvds have a shelf life?
By roryBorealis in forum MediaReplies: 24Last Post: 13th Aug 2008, 16:39 -
Can't play burned DVDs - In need of some serious help!!
By fustrated in forum DVD & Blu-ray PlayersReplies: 13Last Post: 7th Jun 2008, 12:18
