I have a project where I will be burning 150 DVDs of a Montage I created. I just ordered 2 Pioneer 110's, and am planning on putting both of them in my 2 bay external firewire enclosure.
Can I expect good burns while writing to both drives simultaneously through firewire?
It's more of a hassle, but if I have to mount them in my tower, I will... I'd just like to put them in the firewire case if possible.
P.S. If it matters, the firewire case has it's own power supply.
I have tested this with my two burners, a NEC2500 and HP200i. Both of them are in external Oxford 911 firewire cases (same firmware version). Due the speed limitation of the HP200i I only tested burning DVD+R media at 2.5x using Nero.
I think 4 or even 8x should work. -
Transfer/Communications bitrates should be within easy capability of Firewire. Main thing is to have a recording app that supports simultaneous writing to multiple drives (like the full Nero Burning Rom, DiscJuggler, etc).
External HDD Enclosure Question
By Timex in forum ComputerReplies: 4Last Post: 1st Aug 2011, 13:53 -
How to Record using 3 External Burners plus 2 Internal Burners with Speed
By mn072065 in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th May 2011, 18:27 -
External Harddrive Enclosure
By AuroEdge in forum ComputerReplies: 0Last Post: 3rd Jan 2010, 12:20 -
Have they created an external enclosure for pci cards?
By yoda313 in forum ComputerReplies: 13Last Post: 21st Aug 2008, 22:58 -
Firewire External Enclosure for Sony DRU-500A. Help choose..
By donpedro in forum DVD & Blu-ray WritersReplies: 79Last Post: 25th May 2008, 11:52
