I make soundtracks as 48khz wav files, then import them into Encore.
When I make an image file or burn a disc, it takes the time to transcode my audio. What for? Aren't they good already? Is it compressing them?
I understand that with AVI files, transcoding is necessary to create MPEG files. But I don't know what's going on with audio.
I could just tell the program "Don't Encode" on each wav, but I don't know if that's a bad thing or not.
Because ADOBE ENCORE sucks, as it does not support 100% of the DVD spec. I've never heard of it not supporting WAV files, however.
Not sure.
If it's not Encore's fault, then maybe the files are not DVD spec, meaning stereo PCM WAV 48kHz.Want my help? Ask here! (not via PM!)
As far as I can tell, my wav files are cool. I'm transcoding everything now. Seems to be playing nice.
No matter where I go, someone always tells me the programs I'm using suck. I'm starting to get a complex. -
You may of found the answer to this already, being this is an old post, was searching for something and came across this.
If you go into the preferences (Edit->Prefrences)in one of the settings, I believe Encoding, you will see encode audio (change it from Dolby Digital to PCM) That will resolve your problem.Use your head, Side Step the Traps, Snake through the chaos with a SmoothNoodleMaps -
In the project tab, right click on a *.wav file you imported, >transcode settings>don't transcode. If it's truly a stereo PCM 48kHz *.wav file then Encore will leave it alone. To lordsmurf, I mostly use Encore 1.5.1 and DVD-lab (not Pro). Maybe there are aspects Encore sucks, but which DVD spec does it not adhere to? Encore is sometimes restive; to be specific sometimes when I drag a button link to a button on a menu it freezes. Or when I changed the *.m2v file in a timeline to something I encoded with a lower bitrate (via CCEbasic2.70) suddenly it says "cannot transcode, file not found, error 16xxx". But it does mostly (maybe 95%) what I want it to. Maybe you can direct me to a less kvetchy and more stable DVD-authoring program. For example the new Sonic DVDit! 6 Pro hasn't been commented on yet here in dvdrhelp.
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
Transcode 7.1 DTS-Master Audio to 7.1 L-PCM (.wav/.aiff)
By nateo200 in forum Blu-ray RippingReplies: 10Last Post: 27th Apr 2012, 16:57 -
Ripping Episodes without Encore Trying to Transcode - Anyone?
By jdmba in forum DVD RippingReplies: 1Last Post: 2nd Aug 2011, 13:48 -
Finished DVD in Premiere CS5 - transcode in Encore?
By Mylo in forum Authoring (DVD)Replies: 4Last Post: 23rd Feb 2011, 08:55 -
how to transcode from AC3 to WAV
By phpmysql348 in forum AudioReplies: 3Last Post: 7th Sep 2008, 01:46 -
encode/transcode: Why use Encore rather than Premiere Pro?
By vid83 in forum Authoring (DVD)Replies: 2Last Post: 11th Jul 2008, 19:31
