    Sep 2005
    Germany
    After upgrading to 0.0.9t, whenever I try to encode a DV file with any of the mencoder codecs using crop values other than all zeros, I get an
    AppleScript Error
    Can't make "yuv420p" into type number. (-1700)
    This only occurs when there are any crop values filled in, either by auto crop or manually. There's not a problem when all four fields are 0.
    Everything works fine with the ffmpeg codecs, which, unfortunately, cannot do h.264.
    Does anyone know a fix or workaround?
    :wq
  2. Sorry, it's a bug. I'll fix it by tomorrow.
  3. Please try again with the 0.0.9t r3 version which I just uploaded at http://homepage.mac.com/major4/ffmpegX.dmg (no need to reinstall binaries, just download again the disk image and overwrite the application). Please report if it works now.
