How can we amplify an audio with The Sound Forge?
If you're talking about making the soundfile louder, you could try one (or more) of a couple of things:
1. Mix it louder (adjust track fader level)--If that's already at its limit, then...
2. Apply GAIN to it (does same thing as fader, but applies either as file-resave (destructive) or realtime effect (non-destructive).
3. Apply NORMALIZE to it. Does same as gain, but automates by finding what peak is so that you know how high to set the gain. Good for keeping level high without inadvertently adding clipping.
4. Apply COMPRESSION (with GAIN) or LIMITING (with GAIN) to it. Does same as gain, but also changes the dynamic range so that more of the various levels are in a closer range to each other. This makes the overal sound louder--even when sometimes the peaks are quieter.
Sound Forge puzzler...
By mjl1297 in forum Newbie / General discussionsReplies: 3Last Post: 27th Aug 2011, 08:19 -
Using equalizers in Sound Forge 10
By Xdecade in forum AudioReplies: 0Last Post: 6th Jun 2010, 13:12 -
Sound Forge Help
By ZOMBE in forum AudioReplies: 2Last Post: 28th Jun 2009, 07:46 -
Amplify asf audio
By Silus in forum Newbie / General discussionsReplies: 5Last Post: 28th Sep 2008, 20:55 -
Goldwave or Sony.Sound.Forge
By lucid_dreams in forum Newbie / General discussionsReplies: 4Last Post: 1st Mar 2008, 00:33
