I used Toast Titanium 6.0 to quickly burn a Disc Copy of a DVD. It burned it. I tested it on my Daewoo DVD player. It works. I tested it in the Superdrive which burned the copy. It only sees the Audio TS folder.
Weird or what?
Results 1 to 10 of 10
I sometimes see that the VIDEO_TS folder is somewhere down the screen. If you can't scroll down, then yes, that is very wierd.
"Good Luck 007"
In Memory of Desmond Llewelyn -
What version of DVD Player for Mac are you running?
"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
I've got DVD Player 4.5.
No, the Video_TS folder is nowhere to be found. It was in Column view that I couldn't see it. I guess you mean you scroll down to see yours in Icon view. Guess it's really weird, huh? But, really, *where* is it? It's got to be there, or the disk wouldn't play at all in any player. It's not even that it's a hidden folder, 'cause I checked in Terminal with ls -a and all I got was the Audio_TS folder.
Are you sure it got burned in Toast?
Urban Mac User -
VIDEO_TS definitely exists, because otherwise, no stand-alone DVD-player could do playback. AUDIO_TS is empty folder, kind of "reserved for future".
It may be weird, but does it cause any actual harm? Is it like hick-up, uncomfortable to have, but harmless?i-NCO -
Miksu, I have no doubt that the Video_TS folder exists. The problem, however, is that nobody seems to know *where* it is. And it goes further than just being uncomfortable: I actually cannot play back my DVD, unless I'm there sitting in front of my TV and DVD player.
I just can't figure out, for the life of me, how a machine can make a copy which it itself won't later play! -
Have you tried different media that might help with the play back issue if nothing else.
G4 gigabit,PL1.35GHz,
Radeon 9800 Pro 128,1.5GB ram,Pioneer dvr 107D,Running on tiger. -
I have this same problem on my "repaired" Pioneer 109. The orginal died after 6 months and Pioneer, rather than repiar it, sent me another one (new? Refurbished?).
Now when I burn DVDs half the time they can't play back in my computer—the disk is spit out again as if were a blank. I can play these disks fine in a DVD Player. If I set my MAc's system prefs to mount blank DVDs on the desk top, and to launch DVD Player when a DVD is inserted, the disk is still spit out. So my system sees it neither as a burned DVD nor as a blank.
These discs were burned with Toast 7 (TDK 8x media). Others burned on the same eveneing, mount and play just fine.
I have a DVD-R that I burned 1200 songs on, my DVD player only can read 600
By frieday in forum Authoring (DVD)Replies: 3Last Post: 4th Jul 2010, 05:31 -
Video files I add more for a burned disc won't read on my DVD recorder
By Indrek in forum DVD & Blu-ray RecordersReplies: 5Last Post: 8th Jan 2010, 08:30 -
Dual Layer DVD successfully burned, but won't play on a DVD player Help Plz
By Ruudboy in forum Newbie / General discussionsReplies: 9Last Post: 13th Dec 2008, 03:09 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59 -
DVD drive won't read DV burned to DVD-R.
By kunfuzed in forum Newbie / General discussionsReplies: 2Last Post: 23rd May 2007, 07:49
