Bought this DVD player because it's suppose to support CDRW's. I tried copying some MP3's and VCD files onto
CDRW's. It seems to find at least one track on the
CDRW's and starts to play them but no sound or video come
out on the TV. What am I doing wrong?
I've tried both Verbatim and Imation CDRW's. Is there
a special way to write to the CDRW's to make them
readable? Do certain medias not work?
I tried putting some MP3's on a CDR and the Pioneer
plays those fine.
Help!
On my 440.
I use Verbatim CDRW (old 2x disc) for making test VCDS and SVCDs. It works fine every time.
I use VCDImager to make VCD images from mpeg files. I use fireburner to burn these images. No problems whatsoever.
<font size=-1>[ This Message was edited by: bbb on 2001-12-20 20:52:00 ]</font> -
The user's manual says that 440/444 cannot read some CD-R(W) in the following cases:
1) their surface is scratched or dirty;
2) the lens is dirty;
3) the CD-R(W) is not finalized;
4) wrong burning software options used.
Otherwise, the unit must be replaced/repaired as not meeting its specifications. This is my understanding of the problem.
Thanks for the suggestions.
I've been using brand new Verbatim and Imation CDRW's and they aren't on the 'terrible' list under the media reviews so I don't think that's the problem.
How do you 'finalize' a CDRW? I know some CDR's need to be 'closed' before they can be read by some machines. How do you 'close' a CDRW?
What may be some of the wrong options with burning soft ware? At first I thought the problem was using MP3's ripped with VBR encoding. But I tried some MP3's with fixed encoding rate, without success.
I'm going to try VCDImager next.
Pioneer BDR 205 won't play BDMV video discs
By kurbads in forum Blu-ray RippingReplies: 4Last Post: 30th Jan 2012, 04:39 -
CDRW Erasing Cancelled - CDRW NOT WORKing
By Sarao in forum ComputerReplies: 6Last Post: 5th Feb 2010, 11:55 -
Pioneer DV-260 won't open
By spiritgumm in forum DVD & Blu-ray PlayersReplies: 0Last Post: 20th Sep 2009, 22:09 -
Pioneer 510-H Won't Power Up
By groberson in forum DVD & Blu-ray RecordersReplies: 2Last Post: 21st May 2009, 01:11 -
Pioneer DVR 212D won't read Some CD's
By Regm in forum DVD & Blu-ray WritersReplies: 10Last Post: 31st Jan 2008, 17:31
