converted an avi file to dvd using winavi (i just need a quick conversion while my divx capable player is being repaired, and need to get this file to a standard dvd). everything worked fine, but winavi output a vob file that was over 3 gb. problem is nero won't burn .vob files over 2 gb.
any advice as to what freeware is out there that will either divide the .vob file into smaller files, or burn the larger file to a compatible dvd? i guess worst case scenario is that i will encode at a lower quality to keep the vob file under 2 gb. . .
thanks,
d
Use the WINAVI split output file option and voila! (I can't give a direct path to this option as I am @ work but it is on one of the 2 tabs if you select advanced before starting the conversion)
"Quit Playing With The Clock..."
Rudy - Funhouse pinball game -
yeh select file split to 1023m or something..
LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant.
Single large (over1gb) vob into a Simple no menu DVD ?
By nerys in forum Authoring (DVD)Replies: 11Last Post: 28th Feb 2011, 21:27 -
vob to avi no audio - winavi converter
By vendrel in forum AudioReplies: 7Last Post: 23rd Apr 2010, 08:24 -
WinAVI output file size
By Akusai in forum Video ConversionReplies: 21Last Post: 5th Oct 2009, 07:54 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 06:56 -
VirtualDub Output Too Large
By solarblast in forum EditingReplies: 2Last Post: 26th Dec 2007, 21:30
