Ok I recently got a capture card to start getting some tv shows, and I read the guides here about capturing directly to divx, which is what I want to do. It all works fine except for the part in the guide that says
"Select PCM CD Quality (and after you convert ti DivX Audio/MPEG3 because it always get out sync if realtime capturing to divx/mpeg3).
Unfortunately I haven't been able to find a guide or post on here about how to do this, so could someone help me out with a way to convert the PCM audio in a divx to mp3?
Hi CandyCane,
After you've got your DIXV with PCM audio, load the file into virtualdub, select video full processing mode, and audio, compression,(selecte the compression you want) and
hit file, save as avi. (simple as that)
Good luck
DivX conversion
By didikai in forum Video ConversionReplies: 2Last Post: 27th Nov 2011, 12:23 -
DivX 7 Pro mp4 to Divx conversion
By mkochsch in forum Newbie / General discussionsReplies: 1Last Post: 14th Mar 2010, 03:22 -
Ripped dvd conversion to xvid/divx weird audio problem
By victoriabears in forum Video ConversionReplies: 1Last Post: 12th Feb 2009, 14:41 -
Audio very low after VIDEO_TS -> DivX conversion
By mistafro in forum ffmpegX general discussionReplies: 7Last Post: 28th Feb 2008, 19:42 -
DVD to Divx conversion - Problem with audio ! Please Help
By sharartie in forum DVD RippingReplies: 1Last Post: 23rd Aug 2007, 05:13
