    Sep 2003
    I want to create a new thumbnail frame that is portrait instead of landscape. Can anyone help me? I have created a thumbnail picture in Photoshop, saved it as a psd file which can then be imported. I then define a picture from the front of a dvd cover as the picture that will be seen when the dvd is played. The problem is that when I change the default frame for my frame the thumnail image that is shown will not fill the frame.
    The other choice is that I could keep the default frame but how can I import an image as the button without the program from filling the frame ie why will it not the original aspect ratio of the picture?
    Hope this makes sense and that someone can explain what I am doing wrong....
    Kal
    Mar 2004
    Southern California
    TDA will not resize or reshape your picture to fit the screen window. You can try to crop or reshape your pic in photoshop to 4:3 or 16:9, whatever aspect your movie is in, then import to TDA menu. cheers.
