I have been using the free trial of Sonic MyDVD, and it looks really good except that it is very interlaced (I see a lot of lines when there are different cuts) Is there any plug-ins for MyDVD that will deinterlace it? I could deinterlace it with another program first, but I'd rather do it all in one program to save time....
Why on earth would you want to deinterlace?
http://www.digitalfaq.com/dvdguides/capture/understandsource.htm#interlaceWant my help? Ask here! (not via PM!)
You may have it backwards. You want it interlaced not the other way around. If the edges of objects look like a comb that is de-nterlaced. Each field is separate. Your TV will interlace it so you will not see that. The PC does not unless you are viewing through a player SW that will.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
If your source is interlaced then you will be better served keeping it interlaced and letting your playback hardware take care of it for you. Your HD TV will still give you much better quality images from your interlaced footage than you will get if you butcher it on your PC trying to remove the interlacing.
Read my blog here.
Deinterlacing before deshaking?
By Heiler in forum RestorationReplies: 18Last Post: 12th Feb 2013, 02:34 -
Deinterlacing and TempGaussMC
By Tahlos in forum Video ConversionReplies: 7Last Post: 21st Jun 2010, 15:07 -
What is going on with Deinterlacing?!?!
By jieve in forum DVD RippingReplies: 30Last Post: 9th Aug 2009, 16:23 -
OS X Deinterlacing
By ggp759 in forum MacReplies: 4Last Post: 22nd May 2008, 17:37 -
How to use the deinterlacing in the TV when using the TV out from the PC?
By erik1958 in forum Software PlayingReplies: 2Last Post: 9th Jul 2007, 15:07
