Hi, I got a VCD with dual audio on it. I'm using the PC to play the disc, unfortunately it seem there's no way to separate the dual audio using the 3.5mm jack to 2 RCA cable? I have tried to remove one of the RCA output, but still dual language audio is present on the single RCA? Therefore, could some1 pls clarify if there's an alternative way pls? Thank you.
Try demuxing your vcd. Then convert the mp2/mpa file to wave and try open it with an audio editor.
Left channel should be for one language
Right channel for the other language.
Tv with no headphone jack AND rca audio outputs
By gordes04 in forum DVB / IPTVReplies: 27Last Post: 23rd Jun 2013, 22:39 -
Stereo Out to headphone jack (3.5mm)?
By therock003 in forum AudioReplies: 34Last Post: 17th Feb 2012, 01:47 -
Audio/Video jack - is this a headphone jack?
By OM2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th May 2009, 17:10 -
S-video cable..better to use than RCA Jack audio, video cables?
By snafubaby in forum Newbie / General discussionsReplies: 5Last Post: 3rd Jan 2009, 09:38 -
A LIST NEEDED for DVD PLAYERS featuring 5.1 RCA audio outputs
By messhead in forum DVD & Blu-ray PlayersReplies: 2Last Post: 5th Mar 2008, 11:52
