Hi all,
I have looked around on the site for programs to use to convert ogm to avi or ogm to dvd and I need specific info. I mostly need my ogm;s and mkv's to be converted to avi since i am using nerovision to make dvd menus etc. Anyhow I noticed a lot of ppl recommending different programs and what I wanted to know is which one is the best for what I need, im looking for easy to use mostly and also something that doesnt take literally a week to convert 1 file.
Hope u can help me
Mewmix
For ogm to avi:
mencoder -ovc copy -oac pcm -aid # input.ogm output.avi
where # is the number audio stream that you want to keep (if there is more than one.
An ogm's video is always compatible with avi.
Surely Nero vision can handle an ogm directly though?
Converting an mkv to avi can be more complicated since the video is not always compatible. Could be VBR, could be native MPEG4, AVC, RV, etc. -
http://www.aziendeassociate.it/cd.asp?dir=/mplayer <-- my builds.
About time I put some new ones up. -
ok I have it downloaded, gotta read the helpme file since i have no clue how to use it yet, anyhow I also wanted to ask if when you convert ogm to avi, why are the files smaller, the ogm said its 45mins long, avi says its 33 minutes long, im askin for a friend, I havent gotten that far but hes testing and did.
Straight conversion to MP4
By DominionZA in forum Video ConversionReplies: 9Last Post: 20th Apr 2012, 07:43 -
Converting OGM and MKV
By Jeikobu in forum MacReplies: 9Last Post: 3rd Jun 2011, 01:30 -
Straight conversion from VOBs to one TS, keeping languages and subpictures?
By saintq in forum Video ConversionReplies: 2Last Post: 6th Dec 2010, 11:19 -
troubles with MKV/OGM to MP4
By ironmaidens in forum Video ConversionReplies: 6Last Post: 23rd Aug 2008, 14:18 -
Converting OGM/MKV to AVI
By DarkManX4lf in forum DVD RippingReplies: 11Last Post: 30th Dec 2007, 16:16
