    Jan 2004
    Queens
    Some help please. What's the easiest program to use to reauthor a home DVD and create menu's with motion, plus have lots of templates. Is there such a program. Thanks to all. This place is the only place I can find true answers. Thank you all for always helping.
  2. Try Ulead DVD MovieFactory 4.0.It's easy to use and have lot of templates covering many categories.If you want to create professional looking menu's than try Ulead DVD WorkShop 2.0.
    But i think Ulead DVD MovieFactory 4.0 is good for you and it's not that much expensive.
    Jan 2004
    Queens
    thank you so much
    As mentioned, DVDWS2 can make very professional menus, and without a complex user interface (very easy to use!).
    Has lots of templates too, but your best work will always be original content.
    Jan 2004
    Queens
    Does anyone know whick of these have more templates. Unlead My DVD Workshop or Dvit 6 Pro. I have the demo on Unlead MYDVD but do not have the demo on DVDIT 6.0. Glady appreciate any opinion. Thanks
  6. Banned
    Freedonia
    I have never used it, but you might want to check out DVD Menu Studio from the folks at DVD-Lab. Look at
    http://www.mediachance.com/dvdmenu/index.html
    It's much cheaper than the other options mentioned.
  7. DVD-Lab works great as well.
    Quality is my policy.
