well, ive just bought this one
but never stop givving me problems
specially when it comes to movie copyin
i tried many sofwares , it work once, and 10 no
so just wanna know
is sony good, specially this model, and all what i need
only to change this drive, cuz its clear its not working fine
after many tetsting...
or do i have to change to other brand???
Your SONY drive is a REBADGED LITEON drive. What software are you using to backup dvds? DVD DECRYPTER? DVD SHRINK? Look at the GUIDES at the left<<<<<<<<<<<<<<<on how to backup and burn DVD's.
If the drive can be returned get a BENQ 1640 which is better than a REBADGED LITEON or get the SONY 810a that is a REBADGED BENQ 1640. -
Originally Posted by ysfm
What brand of dvd media are you using? Good rule of thumb is to use good quality dvd media not the cheap junk stuff. Use FUJI (TAIYO YUDEN), MAXELL dvd media that's MADE IN JAPAN. -
well, im not so sure about the media
but i tried branded dvds, like imataion and samsung
but i i see ppl using unknown dvds and it work all fine with them
i dont know what they r doing
ill try to check the media and use good one and see
but after all, the drive im using
is it good one which i can rely on if everything is ok??
cuz im takin it back and wanna know if i only
change the drive to the same one
or take other one? -
use DVDINFO PRO or DVD IDENTIFIER to find out the MEDIA CODE/MANUFACTURER. Brand names mean nothing unless you know the MEDIA CODE. Some brands use many different manufacturers such as MEMOREX uses CMC which is junk in my opinion, MAXELL (MADE IN TAIWAN) uses RITEK which is so so....I would strongly suggest you either use good quality dvd media as I already mentioned in my other post to you or return the SONY drive and get a BENQ 1640......
P.S. check out the dvd media section on this site...you'll see how many brand names will use other manufacturers and you'll see the MEDIA CODES.
Problem with Sony DVD RW DRU-830A
By VOD0708 in forum DVD & Blu-ray WritersReplies: 6Last Post: 10th Jan 2010, 14:43 -
/Sony DRU-190A problem
By Quadzilla in forum DVD & Blu-ray WritersReplies: 22Last Post: 7th May 2009, 14:10 -
Sony DRU 800A Problems burning??
By khronos000 in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2007, 17:40 -
Sony DRU-810A question...
By bamabluebird in forum DVD & Blu-ray WritersReplies: 4Last Post: 10th Jul 2007, 10:21 -
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 08:41
