Has anyone attempted to refill the ink cartridges in the Epson R200? I took a cartridge apart to see how it was constructed. There is no sponge as in a lot of cartridges. There was a labyrinth of small chambers. The ink does not flow between them all. There is a small spring near the back of the cartridge that makes me wonder if it is some sort of simple solenoid pump that moves the ink from one part of the cartridge to the other. There was no obvious way to refill the cartridge. Am I missing something?
It's a messy process !
Do a Google search for Negative Pressure Refil and see what you get - basically you have to suck up the ink through the chambers and then reseal the cartridge.
You may find generic cartridges use a different design (eg the more traditional sponge), but the genuine Epson design is an epic construction with vents, diaphragms and wotnot - no doubt designed at least in part with stopping us lot refilling them in mind.
Sadly the days of just squirting some more ink in seem to be gone. Shock, horror !! -
your best bet is to get a chipped refillable r200 ink carts.
browse this thread (Best CIS?) a lot of info on refillabe r200 carts. https://www.videohelp.com/forum/viewtopic.php?t=265796&postdays=0&postorder=asc&start=570
I did a little research and found that the R200 cartridges have a "Smart Chip" that must be reset after filling. I found a web site http://www.epsonchipresetter.com/ that sells a device that resets the chip. They also have refills that are designed to refill the Epson R200 cartridges. They have all six ink colors in the kit.
actually, from indivisual cartridge, Epson already changed the sponged one to spongeless cart.
nowadays, they are not using sponge to control ink usage but "chipset" to produce more unescessary cleaning cycles. -
I been using generic ink for over 2 years 0 issues(Epson C62,and Pixma 3000).
http://search.stores.ebay.com/search/search.dll?query=Epson+R200&srchdesc=y&sid=194883...&submit=Search
resseting hp printer ink after refill
By cyprods in forum Off topicReplies: 1Last Post: 2nd Dec 2011, 21:08 -
Canon CLI8 photo ink cartridges?
By kyrcy in forum ComputerReplies: 2Last Post: 28th Dec 2010, 13:06 -
Remanufactured ink cartridges from supermediastore.com?
By stantheman1976 in forum Newbie / General discussionsReplies: 5Last Post: 1st Jun 2009, 10:03 -
Ink question for refillable Epson R220 cartridges
By Mahime in forum MediaReplies: 3Last Post: 14th Jan 2008, 20:54 -
Resetting HP Printer Ink Level for Refilled Cartridges
By galactica in forum ComputerReplies: 11Last Post: 5th Jun 2007, 04:21
