If I want to take an .avi or .mpg file that I have and chop that up in a program like Pinnacle Studio and then create my own custom menus and then encode that into a DVD. What is that called?
Also, I have used Pinnacle Studio in the past and it worked ok. Could someone give me a list of similiar programs? I just want to be able to take movie files and create menus and chapters and turn that into a DVD.
Thanks for the help.
JT.
"Wanting people to listen, you can't just tap them on the shoulder anymore.
You have to hit them with a sledgehammer,
and then you'll notice you've got their strict attention."
-John Doe in Se7en -
For basic encoding from avi or mpeg to mpeg2
TMPGenc
For create DVD menu and control navigation (DVD Authoring)
TMPGenc DVD Author -
Hi jthompson99,
There's no one term that describes what you want to do. But here's a summary:
"Chopping up" = "cut", usually as part of the (simple) editing stage.
"Create menus" = "authoring". You will end up with VOB, IFO and BUP files.
"Create a DVD (disc)" = "burn". You burn the VOB, IFO and BUP files into a VIDEO_TS folder onto disc. A number of authoring tools do this too.
Look in the "Tools" section for tools that meet your needs, in comparison to Pinnacle Studio.
Here's a few options:
Cutting: VirtualDubMod (does both AVI and MPEGs)
Encoding: I use TMPGenc, but there are a few free ones to get MPEG2.
Authoring: I use TMPGEnc DVD Author
Hope that helps...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
guys, that definitely helps, thanks for the input.
-John Doe in Se7en
Long term storage format.
By DaveQB in forum RestorationReplies: 1Last Post: 23rd Oct 2009, 06:37 -
Is The Term Normalizing Wrong?
By hech54 in forum AudioReplies: 6Last Post: 1st Oct 2009, 14:11 -
Long-term VCR storage
By echo1434 in forum Newbie / General discussionsReplies: 4Last Post: 4th Apr 2009, 10:17 -
Best format to store DV long term
By Craig876 in forum Newbie / General discussionsReplies: 4Last Post: 14th Jan 2009, 06:59 -
Best video format for long term compatibility?
By mart0224 in forum Video ConversionReplies: 11Last Post: 20th Sep 2008, 22:39
