I'm authoring a DVD5 with 21 titles and no menus. Each title has just 1 video stream and 1 audio stream. I calculated the average bitrate using the Java calculator on this website and encoded VBR using CCE. Before I begin authoring with DVDAuthorGUI, my audio and video files together take up 4.25 GB, but the VIDEO_TS folder I get after authoring has a size of 4.49 GB and Nero says that's too big for burning.
I guess my question would be: Does authoring add an extra 11.7 MB per title (see calculation below) as info about each title on the disc, or is something screwing up with the authoring process?
I don't remember this happening with any of my single title discs.
4.49GB - 4.25GB = 0.24GB
(0.24 GB * 1024 MB/GB) / 21 titles = 11.7 MB/Title
Authoring takes up that much so its best to keep the file sizes done to 4.15 gb or less depending on how many titles you use.
Most of it is the "multiplex overhead" (info which video frame corresponds with which audio frame). For standard Audio (CBR; mp2 and most ac3) this may be roughly calculated like this:
Totalsize_in_MB = Videosize_in_MB + Audiosize_in_MB + (VideoDuration_in_seconds * 0.011)GUI for dvdauthor:
https://www.videohelp.com/~gfd/
Need Help using AVStoDVD - Output size is HUGE
By Ronny G in forum Authoring (DVD)Replies: 42Last Post: 23rd Dec 2012, 20:27 -
Captured video huge in size
By Zooropean in forum Newbie / General discussionsReplies: 4Last Post: 25th Mar 2011, 15:55 -
quicktime pro will exporting to h.264 solve this huge file size issue?
By cybershot in forum Newbie / General discussionsReplies: 7Last Post: 10th Oct 2010, 21:43 -
TMPGEnc Maximum File Size for Authoring?
By cym in forum Authoring (DVD)Replies: 3Last Post: 26th May 2010, 01:55 -
Help dubbing avi without make file size huge
By method in forum Newbie / General discussionsReplies: 4Last Post: 10th Aug 2007, 03:51
