I have a DVD of some home movies from a friend of mine. The video is almost 2 hours long plus has a menu etc. I am trying to make another copy for him but can not figure out what format the video is in. It will not play on a set top player at all but will play on a computer DVD. It tried to create a backup with DVD decrypter and it does not even recognize the disc at all. I also tried using DVD shrink and no luck. How can I find out what format it is in so I can convert it to usable MPEG2 to reauthor it for him.
I can tell what ever format it is in, the quality is not very good plus you can see how much of the DVD was used when it was burned and around only half of it was used for almost two hours of footage, so it has been compressed for sure.
How can I tell what format it is and convert it to MPEG2. I understand the quality will still be bad, but the goal is being able to play it on a set top player, not just on a computer.
Thanks for any help.
If in doubt, Google it.
Just copy the disc to an empty folder on your pc, then burn the files onto another disc or use any burning software and make a disc image and burn. There is no reason to use decryptor or dvd shrink.
Google is your Friend
Windows Live Movie Maker: I can't figure out how to get it onto a DVD.
By chelsey_allen in forum Newbie / General discussionsReplies: 3Last Post: 25th Jan 2011, 08:11 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 13:12 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 09:21 -
Cannot figure out which dvd player will work.
By capman21 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 26th Mar 2008, 11:04 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 09:34
