I use TDA to create menus for my 4:3 home videos. The menu created is also 4:3. I have a Panasonic DVD player which "shrinks" 4:3 DVDs for proper display (no stretching) on a 16:9 TV (black stripes on the side). Here's the problem - the video's are displayed correctlly (i.e. shrunk with black bars on edges). However, the menu's area displayed "full screen" without the black bars and are thus "stretched". Any suggestions on how to correct this would be appreciated. Thanks.
wwaag
Read my blog here.
Thought maybe it was something peculiar to TDA, so I tried DVD-Lab Pro. Same result--video OK but menus are stretched.
I think that your SA Player has a Option for it (I only know it from the other way round: 16:9 Menus get stetched in height on 4:3 TVs if the Player has been set up to use "Automatik Pan&Scan"). This would solve the problem for all DVDs without any additional work.
For the DVD itself the Option can be set with IfoEdit: Open (probably each!) IFO, click on the line:
VMGM_MAT-Video Manager Information Managment Table
in the upper window, and then doubleclick on the line:
[00000100] Video attributes of... (either VMGM VOBS or VTSM_VOBS)
In the popup window you may set the options for 'Static':
Automatic Pan&Scan
Automatic Letterboxed
Disable Automatic Pan&Scan and enable Automatic Letterboxed.GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Thanks for the replies. Made changes as suggested but still doesn't work--4:3 menus remain stretched without the sidebars. It seems that the options deal with how a 16:9 image is viewed on a 4:3 TV and not vice-versa. For whatever reason, my player will correctly "shrink" the video portions of the DVD, but will not "shrink" the static menus. I tried all cobinations of options available, but the result is the same. If all else fails, I can always create a 16:9 menu with 4:3 title sets for the video portion. Again, thanks.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 14:08 -
Panasonic DMR-EZ48VK How do I get into its hidden setup menu (Service Menu)
By RS456 in forum DVD & Blu-ray RecordersReplies: 20Last Post: 14th Nov 2011, 02:50 -
Continuous play of root menu audio throughout all menu's
By breakbred101 in forum Authoring (DVD)Replies: 3Last Post: 28th Apr 2009, 19:37 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 12:01 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 12:36
