Hello,
I am trying to convert the wmv video clip and mpeg2 video clip to divx or to xvid.
i resize the video clip to 640x480 what must be the bitrate for keeping a higth quality of picture ?
i use 780kps as bitrate which this bitrate i saw the square on the picture.
divx(780kps) is look best than xvid(900kps) ? or i make a wromg set up ?
I use virtualdub as toolhttps://www.videohelp.com/forum/viewtopic.php?t=244151
H
codec divx 6 and xvid1.1.0
Don't worry about bitrates. Use Xvid's Quantization mode (constant quality). Select the quality you want, encode in a single pass. Try Q values between 2 and 4.
A lot depends on your source, too. It will be difficult to obtain a suitable result if you're resizing a 320 x 240 picture (for example) to 640 x 480 and expect it to retain the same quality. There's also a number of filters you could introduce to assist (either virtualdub's own filters or some AVISynth ones) but it really depends on how much time and effort you want to spend on making this look as good as it can be.
Can you provide more info / stats regarding your source ?If in doubt, Google it.
MKV to XVID lowers bitrate?
By zovx in forum Video ConversionReplies: 3Last Post: 7th Feb 2010, 13:22 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47 -
Trouble Finding Bitrate for DivX Xvid for CD-r
By 4194 in forum DVD RippingReplies: 9Last Post: 24th Aug 2007, 11:41 -
Xvid won't encode at the right bitrate?
By dimtim in forum Video ConversionReplies: 2Last Post: 18th Jul 2007, 21:58 -
Bitrate suggestion? -> XVID to MP4 <-
By brijazz in forum Video ConversionReplies: 6Last Post: 8th Jun 2007, 17:08
