ok I have a video on a disc that I bought from a website about them going to Nintendo Spaceworld in 2001 for the launch of the gamecube.
Unfortunately I want to take the WMV off teh disc and burn it to VCD so I can watch it on TV. But when I try to copy it from the disc I get a Cyclic Redundacy check error.
Is there a problem with the disc or with my PC?
And am I SOL on ever getting the file off the disc so I can make a VCD.
It's not the fall that hurts it's the sudden stop
well you have a couple of options.
If you have a capture card you hook up a dvd player and capture it in realtime.
But you're probably better off using another ripper like dvddecrypter or dvdfabdecrypter.
Also is the disc scratched? Thats a symptom of that error also.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
ive had the same problem with dvds and dvdfabdecrypter solved the problem where dvddecrypter and dvdshrink failed.Originally Posted by Namrepus221I love it when a plan comes together!
Well here's the thing...
It's not a DVD.
It's a CD with a WMV file on it. I want to take the WMV off of it, so I can burn it to DVD.
I can't because as it's copying to the folder I have, it give that error.It's not the fall that hurts it's the sudden stop -
or try another drive, if you have one. i think my dvd-rom is starting to crap out cause i have that same problem sometimes. if i put the disk in my burner, though, it reads fine. these cheap drives don't always last forever!
I am just a worthless liar,
I am just an imbecil -
dvd shrink usualle does that with scratched discs.
but I use dvdfabdecrypter and it works.
although this time im getting an error message reading
get information failed 4096.
Cyclic redundancy check error
By Arch3type in forum ComputerReplies: 6Last Post: 16th Jan 2011, 02:32 -
How to correct this Cyclic Jitter ?
By zenzen1 in forum Newbie / General discussionsReplies: 3Last Post: 8th Aug 2009, 19:43 -
I/O Error (Cyclic Redundancy Check) - where does my problem lie?
By xxjustinukxx in forum Authoring (DVD)Replies: 3Last Post: 11th Apr 2008, 22:35 -
data redundancy?
By beer31 in forum ComputerReplies: 5Last Post: 23rd Aug 2007, 01:32 -
Cyclical redundancy, what is it?
By moviebuff2 in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2007, 10:47
