Hi guys,
I have used DVD2SVCD to extract some chapter from 2 dvds and the result was 2 big mpeg files.
I wanted to create a dvd with video clips so I used Mpeg Video Wizard from Womble to extract the clips and used fade in/out effect for each separated file (for audio and video).
The results from the clips extracted from dvd1 are jumpy when watching in the tv but from dvd2 the video is nice and smooth.
Do you have a guess from what is happening here and how to get rid of this issue?
Thanks for any help!
superpina.
Your field order got reversed somehow. Flip it in Restream.
Hi lordsmurf!
I have used restream to show the field order and both files are tff. The difference between the good one and the bad one is the fields codecs:
for the bad one is: IPBBPBB
for the good one is: IBBPBBPBBPBBPBB
I'll try to revert the fields and let you know.
Regards,
Alex.superpina. -
http://www.digitalfaq.com/dvdguides/capture/atimpeg/restream.htm
in case you don't know how to flip them.Want my help? Ask here! (not via PM!)
So what.Originally Posted by byteguy
That's how fields are ordered, the flags.Want my help? Ask here! (not via PM!)
AVI Field Order
By Ash McKenzie in forum Newbie / General discussionsReplies: 1Last Post: 1st May 2012, 00:52 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 00:38 -
field order and cce
By cd090580 in forum Newbie / General discussionsReplies: 3Last Post: 17th May 2008, 16:11 -
Determining field order
By dadrab in forum Video ConversionReplies: 2Last Post: 4th Oct 2007, 15:09 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 16:14
