  1. My Pioneer 106D is having trouble reading some discs.
    1 disc is a dvd I created on my old pc using Pinnacle but it refuses to play on my new pc - I took the 106 from my old pc and am using it in the new. The disc plays fine on my stand alone dvd players
    The other disc is a bunch of avi files which again works fine in my Xbox when I look at it in explorer it just shows as blank.
    Any ideas of what the problem might be ?
    Jim
    USA
    Dust on the laser lens? Have you tried cleaning it?
  3. I had problems reading +R disc's with my 106D, so I switched to -R and all my problems seem to be solved so it might be a media problem.
    https://www.videohelp.com/forum/viewtopic.php?t=272886
    HTH
    May 2003
    I used to have the same problem with the sony burner I had before,I tried the pioneer and I had the same problem then I switched to a lite on dvd burner and now I can read any dvd I load into it .
