I have tried a hell of a lot of things to stop my video going out of sync but have had little luck. This includes running the video through womble etc.
As a last resort, can I request an "audio offset" feature in the next release. I think if I can enter a small positive or negative ms value then I will be able to finally get my audio to match the video.
Can you explain your sync issues? What are your sources: mpeg, avi, pal conversions?
Most of the time I use SVCD2DVD to create PAL DVDs from PAL MPEG2 files I extract from my TiVo. The files play *very slightly* out of sync when I watch them in media player but not enough so you'd notice if you weren't looking for it.
After being remuxed by SVCD2DVD the resultant video is a lot more out of sync and makes it v. difficult to watch. I tried playing the original files in VirtualDub (as suggested) and they appeared to play fine with no significant sync issues.
I recently used SVCD2DVD on a couple of DivX files and the resultant video is hugely out of sync on my DVD player. I am prepared to accept that the sources for the DivX may have been less than perfect though.
If you want, I will try and prepare a smallish example of these problems to upload for your analysis. -
Ok. Can you send me a mpeg sample that exibits this - i will look into it (use the MakeSample tool in the "SVCD2DVD v2\Tools" folder). FTP it to ftp://BetaTester:badger@ftp.svcd2dvdmpg.com:7676/
As for the divx issue: If it is out of sync from the outset and remains so, have a look at the solution here: https://www.videohelp.com/forum/viewtopic.php?p=1338598#1338598SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
BATCH video + audio free'n'handy DEMUXER request - now, please
By bulgom in forum Video ConversionReplies: 0Last Post: 21st Nov 2011, 13:21 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
feature request: Vob2mpg pro command line option for audio stream selection
By Ahimoth in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 8th Sep 2009, 06:42 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
