Closed Thread
  1. Hello
    I'd like to ask you all what kind of codec installation do you prefer.
    Install manually, one by one (xvid, ac3, ffdshow, etc)? If yes, wich ones do you install?
    Install a codec pack, like Nimo for example. If yes, wich codec pack?
    You are in breach of the forum rules and are being issued with a formal warning. Take all that crap out of your signature. It's pure warez links. Unacceptable.
    / Moderator lordsmurf
  2. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Don't install packs they cause conflicts, install individual ones as you need them.
  3. To have all DivX working fine, wich individual installing do you recommend? (Video & Audio)
    For example, i'm getting a annoying image in "Star Wars - Revenge of the Sith" and it doesn't happen in other movies.
