If I buy Region 2 Discs, can I then use DVD Shrinik to convert to Regon Free? Thanks
Yes, but you may need region-free tools to get it into DVDShrink in the first place, or alternatively, you may need to change the default region on your DVD-ROM (by default windows lets you change it 5 times). Or you could flash your DVD-ROM with a Region Free Firmware from http://forum.rpc1.org/dl_all.php .
Although you don't have to use DVDShrink. AFAIK even just ripping with DVDDecrypter should make it region-free.
See https://www.videohelp.com/tools?s=25#25 for other Region Free Tools that may assist.If in doubt, Google it. -
I forgot to mention that I use DVD Decrypter to rip, so if I use DVD Decr, ten it should be ok? Thanks for the quick resposnse.
question about dvd shrink
By marlo in forum Authoring (DVD)Replies: 5Last Post: 29th Aug 2010, 05:22 -
Hello I'm New & I Have A Question About DVD Shrink 3.2
By taffy1967 in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2010, 05:28 -
question about DVD Shrink
By Bamahusker in forum DVD RippingReplies: 7Last Post: 1st Mar 2010, 21:48 -
DVD Shrink and Nero Recode question.
By siratfus in forum DVD RippingReplies: 8Last Post: 13th Jan 2010, 22:49 -
question regarding analyze in DVD Shrink
By Bamahusker in forum Newbie / General discussionsReplies: 2Last Post: 8th Jul 2007, 09:31
