A few issues I have come across in the past few days (ffmpegX is still a great app though):
1.) When using a 1080p Uncompressed source, and trying to encode to 1080p MPEG-2, the resulting file is a letterboxed 1440x1080 movie. Is the max resolution for the ffmpeg engine 1440x1080? If so, how would I enable anamorphic 1080p MPEG-2 encoding? And, will the mpeg2enc engine ever support resolutions above 720x480 for MPEG-2?
2.) When using a 720x480 Uncompressed 4:3 IAR source movie, and encoding to 720x480 4:3 MPEG-2, the resulting playback of the movie is 3:2. 640x480 square pixel source must be used for proper desktop playback of encoded movie.
3.) Encoding to H264 causes ffmpegX to immediately stop and finish encoding. I have installed the new binaries (twice) and even went back to 0.0.9s (reinstalled appropriate binaries as well) and same issue appeared. The thing is, I could have sworn I did a successful test encode with 0.0.9s and H264 in the past. Here are the logs:
From BlacMagic 8bit 640x480 source and 0.0.9t:
- Encoding started on Mon Sep 5 03:01:40 EDT 2005
MEncoder dev-CVS-050814-13:46-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0x2783b3e5
ISO: File Type Major Brand: Original QuickTime
Quicktime/MOV file format detected.
Cannot find codec matching selected -vo and video format 0x79755632.
MOV track #0: 1079 chunks, 0 samples
Image size: 640 x 480 (24 bpp)
Display size: 640 x 480
Fourcc: yuV2 Codec: ''
VIDEO: [yuV2] 640x480 24bpp 23.980 fps 0.0 kbps ( 0.0 kbyte/s)
[V] filefmt:7 fourcc:0x79755632 size:640x480 fps:23.98 ftime:=0.0417
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=640 h=480]
Opening video filter: [pp=0x33]
Read DOCS/HTML/en/codecs.html!
Exiting...
From BlackMagic 10bit 640x480 source and 0.0.9t:
- Encoding started on Mon Sep 5 03:00:48 EDT 2005
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0x3751f3e5
Cannot find codec matching selected -vo and video format 0x30313276.
Fourcc: 012v Codec: ''
VIDEO: [012v] 640x480 24bpp 23.980 fps 0.0 kbps ( 0.0 kbyte/s)
[V] filefmt:7 fourcc:0x30313276 size:640x480 fps:23.98 ftime:=0.0417
Exiting...
From BlacMagic 8bit 640x480 source and 0.0.9s:
- Encoding started on Mon Sep 5 03:09:02 EDT 2005
MEncoder dev-CVS-050123-19:55-3.3 (C) 2000-2005 MPlayer Team
AltiVec found
CPU: PowerPC
QuickTime/MOV file format detected.
MOV: longest streams: A: #-1 (0 samples) V: #0 (1079 samples)
MOV: selected audio stream (0) does not exists
Exiting...
ct) osd: 1
From BlackMagic 10bit 640x480 source and 0.0.9s:
- Encoding started on Mon Sep 5 03:10:08 EDT 2005
AltiVec found
CPU: PowerPC
Exiting...
Expand: -1 x -1, -1 ; -1 (-1=autodetect) osd: 1
Square pixels or 16:9 Pixel aspect ratio?
By Scherwin in forum Video ConversionReplies: 6Last Post: 18th May 2010, 13:47 -
Encode to non-square pixel xvid?
By rebl in forum Newbie / General discussionsReplies: 12Last Post: 6th Jan 2010, 23:11 -
Audio Sync issues under Vista 64 and H264/AC3 MKV files at 1080p
By tarrantm in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2009, 22:56
