I use Vegas 5 for video editing but I have some problem with rendering the project. When I want to render, Vegas offers me only SVCD and DVD template in MPEG 2 field (PAL or NTSC), so when I press the CUSTOM field nothing's happen.I have already registered main concept MPEG plugin but I still can't use for example, bitrate of the rendered video, (choosing between constant and variable bitrate, bitrate value and etc.)
In that case I use DEBUG frame server and encoding the video with TMPGenc
2.5 but here is the main problem. For instance, AVI file about 4 hours takes tooooo long for encoding (Pentium IV, 1,7 GHz), about 12 hours with constant bitrate 8000 Kbs, I dont even thing using variable bitrate!!! I tryed WinAvi Video Converter trough frame server, but quality of MPEG is not so good like when rendering with TMPGenc.Some good advice?
Regards.
QUALITY HAS A NAME
mainconcept mpeg encoder, canopus procoder or cce basic.
You don't have these menus? Try reinstall.
http://www.kiva.org/about
What is Rendering?
By jbitakis in forum Video Streaming DownloadingReplies: 4Last Post: 1st Jan 2012, 23:27 -
Need help - rendering in Vegas
By Rairun in forum Newbie / General discussionsReplies: 4Last Post: 21st Jul 2011, 19:51 -
Convert .FLV to another (.avi or .mpg) WITHOUT re-rendering?
By DW in forum Video ConversionReplies: 4Last Post: 3rd Feb 2011, 18:13 -
Need Rendering Tips!
By reece_wallace in forum EditingReplies: 1Last Post: 31st Dec 2009, 00:15 -
Rendering
By evilzma in forum Newbie / General discussionsReplies: 34Last Post: 20th Jun 2009, 16:19
