I made a menu and tried the render motion option to give it an intro effect. After the compilation and I tested it with PowerDVD...it seems that the render motion keeps on looping I dont have anything checked. I'm using DVDLab PRO
Heres a screenshot of what I'm talking about
Results 1 to 22 of 22
Could it be that PowerDVD is set to "Loop"/"Time out". Sorry this is all the help I can offer as I have never used DVDlab Pro.
all mothin menus loop, i thought!?
I am just a worthless liar,
I am just an imbecil -
well i just want an intro effect that doesn't loop...is there a way you can do this?
You may need to render all your motion, and set this to play 1st. Then once the movie (motion) has finished link it to a still menu with all the buttons etc you need.
I do this quiet a lot using DLP render motion feature.
Simply create your motion, and then import the output as a new asset. Add it as a new movie and set it to be first play. Then link it to the actual menu (I tend to use a screen cap from the final frame of the motion menu as a background to ensure seamless playback)
Good LuckWho is watching the watchers. -
I guess you can do it that way, but there are flaws to it. Once you click the menu button it would go to the menu screen not the render motion first. So it becomes pointless. Thanks for you the help though. I guess I'll just forget about the motion menu and just click with a normal menu
oh crap...i got the intro effect render motion to work but now the audio loops where the render motion loops.
or set your intro as one menu that links to another (the actual menu). that way, you should return to the intro since it is a menu, not a movie clip.
but surely there's a better way! i just started messing with dvdlab, but i don't have pro.I am just a worthless liar,
yeah good idea. Seems like it would work. Going to try it out tonight and see if there are any flaws to it. Thanks
I assume you want the menu to play once, then become static. If you want to keep the menu from looping, use the PBC tab to the right of the menu layout screen. In the duration box, type the letter "a", it should give you a "a/v" in the box. This will make the menu duration last as long as the motion then stop.
Steve -
I tried the delay menu...I don't think it works or I couldn't get it to work. Got the menu to stop looping but the audio is seperate from the mpv and seems to be looping at the same time the delay menu becomes static
in the PBC tab the a/v is already there by default which doesn't work. -
You've almost got it. This isn't that hard to do.
Make 2 menu's with the same buttons and everything. One motion, one still.
Make an invisible all button on the motion menu to link to the still menu. Close it out of the navigation lines so it's unclickable.
Set pbc on the motion menu to a/v and then force highlight and force activate the invisible button.
This will play the audio/video once and switch to the still with no audio. Presto. And your buttons work whether it's in motion or not. -
Is the audio the same length as the video? If not, that may be why the audio is looping.
Steve -
the video is just a menu I created but with an intro effect. It's like 6-7 secs long. The audio is a soundtrack I imported.
The video will loop as long as the audio track.
Either increase the video to match the audio length, or decrease the audio length.Cheers, Jim
My DVDLab Guides
DVDlab PRO : Motion menu, cells, missing button highlights !
By TheCap in forum Authoring (DVD)Replies: 18Last Post: 13th Jul 2011, 11:14 -
DVD Lab Pro 2's Render Menu Motion - Intro and Loop Questions?
By xhonzi in forum Authoring (DVD)Replies: 3Last Post: 21st Sep 2009, 17:52 -
Motion Menus in DVDLab Pro question
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 1Last Post: 8th Mar 2009, 16:47 -
One Cell Motion Render in DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 0Last Post: 23rd May 2008, 09:07 -
DVDLab PRO - Music in Menu
By poutniksantiago in forum Authoring (DVD)Replies: 8Last Post: 15th Nov 2007, 07:28
