    Apr 2005
    Montreal, Canada
    Hey, I'm using Adobe Encore DVD 1.5.1 and for some strange reason the subtitle track is not allowing the dvd to build. It gets as far as Analyzing Project when I get an "Unknown DVD Error -1". When I remove the subtitle track it goes smoothly through the build process.
    I thought it might be a problem with the subtitles I was importing, but then I tried adding a subtitle manually in the monitor window. This gets me the same error as before.
    I've also tried reinstalling Adobe Encore, no luck.
    Has anyone had this problem before?
    May 2003
    Columbus, OH, USA
    I would recommend that you visit the Adobe Forums at http://www.adobe.com/support/forums/main.html . I haven't started working with subtitles in Adobe Encore DVD, but I have read about some issues that Encore DVD has when it comes to subtitles.
    Tools used: ScenalyzerLive 4.0, Adobe Premiere Pro 2.0, Adobe After Effects 7.0 Professional, Adobe Encore DVD 2.0, IFOedit 0.96, DVD-lab PRO 1.53, Adobe Audition 2.0
