I followed this (http://www.vcdhelp.com/vcdmenun55.htm) guid and made a VCD with it no problem. Then when I tried to play it back on my PC I can not. With I-vcd player it says error and with WIN DVD which can also play VCD's it never lets me get past the menue.
Don't worry, you probably didn't do anything wrong.
Nero5.5 has a bug when it authors still menus. These menus don't work on most software VCD/DVD players and even on some hardware players.
You will probably have to try another proggy.
VCD Toolkit, VideoPack 4, VCDImager +/- GUI is probably your best bet.
VCDImager is open source freeware. There are now a few GUIs out that make it easier to use for beginners (e.g., TSCV or VCD Easy -- do a search for TSCV or VCD Easy for places to download and guides).
For some detailed information on authoring with VCDImager: http://www.geocities.com/medinotes/vcd
Regards.
Michael Tam
w: Morsels of Evidence
DVDFab - rip BD, including menues WITHOUT main title
By ptaylor999 in forum Blu-ray RippingReplies: 5Last Post: 9th Sep 2014, 13:37 -
Help with making menues with Nero 8 (Vision 5)!
By Ikka in forum Newbie / General discussionsReplies: 0Last Post: 3rd Feb 2008, 11:24 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Creating top level and sublevel DVD menues in PS 11+
By G16aByT3 in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2007, 10:06 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
