okies when I burn a dvd from nero it limits the # of letters I can use
for example
HI_MY_GRADUATION_MO
but in dvd shrink I can burn the whole title like HI_MY_GRADUATION_MOVIE3
is there anyway around this nero limitation because I know I could do it before in nero 5 but in nero 6 I don't know the right setting I hate my titles being cut off!![]()
terramir
Results 1 to 12 of 12
added videocard had to downclock my proc got 10 C hotter in my case time to ducts that sucker ;@ had to down my overclock was 2200mhz now 2100 mhz :'(
i dont burn my dvd's with nero, but what you could do is use the image writer to output an image file (nrg) & then use dvd decrypter to change the volume label..
just click tools/iso/change volume label.. you may have to have it show .nrg files though. and then enter your desired volume label for it.
well anymore answers that one's ok but time consuming
Anyone a master of nero?
terramiradded videocard had to downclock my proc got 10 C hotter in my case time to ducts that sucker ;@ had to down my overclock was 2200mhz now 2100 mhz :'( -
I'm using Nero 6.3 and if I use the DVD-Video template, there is a selector under 'ISO' for the number of characters in a filename. Mine is set to 31 by default, the other option is 18. Is that what you are looking for?
nope that ain't it because that is for file names it's the title I'm concerned about I might have to go back to nero 5.5 but then I would have to give up the the burn plug-in in shrink
Instead of using NERO to burn just use DVD DECRYPTER. With DVD SHRINK you can set it to create a ISO IMAGE instead of creating a VIDEO_TS FOLDER. In DVD SHRINK there is a PLUG-IN for burning with DECRYPTER as well or you could just create the ISO image then open up DECRYPTER to burn.Originally Posted by terramir
Nero 6 is fubar.
This is one of its many bugs.Want my help? Ask here! (not via PM!)
I disagree. Works fine for me, and millions of others around the world.Originally Posted by lordsmurf
I get a bit of "glass house" syndrome when people complain about Nero, Microsoft, + or -, etc etc.
Everything always seems to work for me <shrug>If in doubt, Google it. -
i wont touch nero with a 10 foot poll for burning dvd-video.. it's burned me too many times in the past.. i'll do data dvd's & cd-r's though.
i was using recordnow max for the longest time, but i've become quite dissappointed in their new 7.x version.. it's good for dual layer discs.. but if i'm burning a dvd5 dvd-video, imgtool classic -> dvd decrypter all the way.
Converting a 480x720 2:3 short to a 1280x720 16:9 HD short.
By Cyrax9 in forum MacReplies: 2Last Post: 14th Feb 2011, 17:40 -
Re-Naming AVI Files
By Naquada in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2010, 02:39 -
The naming of Hard drives & Burners on WINDOWS VISTA
By orfajackson in forum ComputerReplies: 2Last Post: 3rd Jun 2009, 15:00 -
Disc name/label being cut short in Nero.
By richard_m_morales in forum Authoring (DVD)Replies: 5Last Post: 25th Sep 2008, 13:20 -
Problem with naming DVD's
By KamilATL in forum Newbie / General discussionsReplies: 1Last Post: 28th Dec 2007, 15:07
