I have a DVD of nirvana at reading 92, and used DVD-lab pro to join and demultiplex it. So I have a big MPV file with no audio I also made a joined .vob file in case that was what i would need. So I went to the guides on how to remove logos and subtitles and almost all were using VirtualDub with a plugin (Virtualdub Logoaway filter, MSU Subtitle&Logo Remover). I also tryed Subrip. Subrip did not work at all. and if I try to load the MPV or Vob file into VirtualDub it says "no video frames found in mpeg file". Is there anyway i can get an mpeg2 file to load into VirtualDub.
Here is what it looks like
What I would like to do is put a black box over the time code.
Thanks for any help
Chris
try using virtualdubmpeg or virtualdubmod instead
Read my blog here.
Originally Posted by guns1inger
I am using a black logo to cover up the timecode and it looks good in virtualdubmod. But is there anyway to output it in mpv formate with the logo and keep the full quality intact?
I really dont want to convert the file formate in anyway. I just want to place something over the timecode. -
no. You cannot change the content of the video without reencoding. What you can do is frameserve from virtualdub to your encoder so you don't need to do an intermediate encode to avi.
Read my blog here.
Removing timecode from screen
By yabastamedia in forum Video ConversionReplies: 1Last Post: 18th Jan 2011, 04:43 -
Converting drop frame timecode to non drop frame timecode, and vice versa
By picrade in forum ProgrammingReplies: 1Last Post: 1st Mar 2008, 04:22 -
Looking for a Stand alone, cheap, DVD recorder, timecode on screen.
By AtomX in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Feb 2008, 16:10 -
DVD Lab Pro timecode problem on Vista
By jonghyunchung in forum Authoring (DVD)Replies: 1Last Post: 4th Jan 2008, 19:58 -
Panasonic DVD recorder & timecode breaks / audio dropouts
By webstar in forum DVD & Blu-ray RecordersReplies: 8Last Post: 23rd Jul 2007, 17:43
