I have been using Ulead DVD Workshop 2.0 for nearly a year and i am quite satisfy with it.But now i wanted to burn couple of DVD's with DTS sound tracks and unfortunately DVD Workshop 2 does'nt suppot DTS import and export feature so i came upto DVDlab Pro.I downloaded it today and currently evaluating it.Here is the problem, i know this question might make someone annoyed so sorry for that.
I created one Thumbnail Scene Selection menu from the pre-defined templates and it was created perfectly, then i created a custom menu and added a Frame from objects asset in my menu and linked it to my chapter by right clicking on the frame>Link>Movie 2>Chapter 7.
The chapter got linked but the image of the chapter was not shown in the frame, as it does in Ulead DVD Workshop 2.Then i found a button saying "Insert Chapter Still" and inserted the respected chapter still but it does'nt got fit in the frame and it was very difficult to adjust it manualy.I know that i am doing something wrong so plz a little help can solve my problem.Thnx a lot.
Regards![]()
Sohaib Razzaq
Put in the still first, resize.
Put the frame over it.
Look at the send forward, and send back buttons.Cheers, Jim
My DVDLab Guides -
I still can't get it to work.Plz can you be a little more specific.
No one here use DVDlab Pro. -
Find the portion of the movie you want for a still, in the preview box.
Drag and drop it onto the menu.
Resize and move it where you want it.
Go to assets, Objects, Frames, and drag the frame you want to your menu, over top of the still.
It will resize itself to fit the still.
If the still is linked, the frame will inherit the link.
I doubt you're doing anything wrong.
You can zoom in on the menu, so it's easier to adjust things.Cheers, Jim
My DVDLab Guides -
Thanks man, now i got it, after putting the still i was supposed to put the frame on the still which i was not doing.Succesfully burned two copies of the DVD and have just purchased DVDlab Pro 1.53.It's a very good authoring tool.Best of it is that it supports DTS Audio import which many other professional authoring tools like Encore DVD 1.5 or Ulead DVD Workshop 2 don't do.
Thanks very much for your help reboot.
Warmest Regards
Sohaib Razzaq
Building a custom bluray disc
By BlurayGuy in forum Blu-ray RippingReplies: 9Last Post: 25th Feb 2012, 00:25 -
How do I create custom DVD menus?
By aple in forum Newbie / General discussionsReplies: 6Last Post: 21st Jul 2011, 21:25 -
Motion Menus in DVDLab Pro question
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 1Last Post: 8th Mar 2009, 17:47 -
How can i do switched menus with videos in Dvdlab pro?
By wan2no in forum Newbie / General discussionsReplies: 1Last Post: 26th Jan 2009, 00:54 -
Building my dvd with some menus
By KYOPOWER in forum EditingReplies: 3Last Post: 25th Sep 2008, 12:58
