Hi,
I'm having odd problems with VOB files. I used MacTheRipper to get a VOB file from a DVD I have, because I wanted to convert it to PSP's .mp4 format. I usually use 0seX, but that kept crashing every time I put the disc in so I had to make do with MTR. After I ripped the file, I used VLC to view it. Now here's where the problems start, the movie plays fine, but the soundtrack is from the director's commentary, RIGHT from the beginning - obviously making it unwatchable. I opened up ffmpegX to see how that plays the same VOB file. When I preview it in ffmpegX (through mplayer?), the VOB file plays with the correct sound, no director's commentary to be heard anywhere! So, I went ahead and used ffmpegX to convert it to PSP format, and guess what? The converted .mp4 file has the director's commentary audio through the whole film...what is up with this?
Is there a way to select an audio stream when ripping a VOB file? I tried converting the same file via iPSP and still got the same problem. Also, are there any other VOB rippers anyone can recommend?
Thanks.
EDIT: I tried using Yade X to rip the VOB file, it rips, but when it finished ripping, it shows an error message saying cannot play it back. I check my folder and the file is there, over 2GB. I opened the VOB in VLC and played it:
VLC shows that it is playing, but I just get a blank screen and the timer on the VLC menu is at 0:01, not moving. I use the track bar to move it forward and see that it shows a blank screen until 00:00:29 seconds, when the movie starts, correct sound and all. But when it starts, the counter on VLC shows up odd, the seconds change, but it takes 3 seconds for it to go from 00:00:29 to 00:00:30 and so on. The movie plays fine. Any ideas as to what the problem could be? Also, are there any VOB editors for OSX where I can get rid of the 28 seconds of useless pitch black at the beginning? Also, is there any chance I have selected something wrong in Yade X before I started the rip?
P.S. I'm trying to rip the VOB of Resident Evil Apocalypse.
How do I go about doing that? I have MTR 2.6.6. I have put my DVD in, gone to the mode tab and selected Title-Chaper Extraction. I have chosen the Main Feature to extract. There is only the option of "1 Angle". The next option shows "SChtp1", if I click the drop down menu, I can choose from SChtp1-28. Then next option is EChtp1, and again, I can choose from EChtp1-28 if I hit the drop down menu. The last two options are two buttons, D and streams. I don't know what D stands for, but if I hit Streams, a tray opens up and shows the following:
Video Stream: Main feature details here (1 hour 37 mins)
Audio Streams: EN AC3 6CH, EN AC3 2CH, ES AC3 6CH, EN AC3 2CH, EN AC3 2CH, EN AC3 2CH
(note: all of the above audio streams are selected)
Subtitles Streams: there are a whole lot available, but none of them are selected.
I don't see options for track 0/1/etc.
BTW, in my preferences, I see the option to enable PGC Mode in Title/Chapter mode - I have it enabled - could this be a problem?
The folder you have is the individual video and audio files that have been demuxed. Maybe try finding which of the audio streams is the one that you want and remux that with the video with the ffmpegX Tools.
Ripping VOB files in GK
By eliqush in forum EditingReplies: 6Last Post: 29th Jul 2009, 13:54 -
Weird Audio problems....
By Superstar24 in forum Newbie / General discussionsReplies: 10Last Post: 15th Jun 2008, 20:19 -
Ripping Kiki's Delivery service, Weird issue with jumbled vid and audio Vob
By AussieHusky in forum DVD RippingReplies: 2Last Post: 20th Feb 2008, 08:05 -
ripping to vob vs Xvid/mp4
By simoupnorth in forum DVD RippingReplies: 4Last Post: 9th Jan 2008, 19:11 -
Slow FPS and weird sound problems
By desantnik in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 13th Dec 2007, 16:33
