  1. Member VERVE's Avatar
    Aug 2004
    Dubai, UAE
    Hi all,
    I have a 30+ sec movie on my pc that displays as a (screensaver).
    1- what format is a screensaver usually?
    2- how can I convert it to .avi?
    Elaborate as much as u can please.
    This is extremely urgent, it's for a client.
    PS: this screensaver movie used " indeo codec". That, I'm sure off.
    Help Please,
    VERVE
    God Bless Lebanon...
    Apr 2004
    Miskatonic U
    Can you find the avi as a seperate file ? If so, you have no problems. If you cannot, because somehow it has been embedded in the screensaver, you are pretty much screwed. You might be able to try a screen capture program, such as camtasia, however most of these won't grab screensavers, and may struggle to keep the framerate high enough to get a decent picture.
    That it requires a codec to be installed seems to imply that a video does exist, so I would start by searching for the file.
    Read my blog here.
    Dec 2004
    Australia
    A resource hacker should be able to extract it from the exe/scr file.
  4. Member VERVE's Avatar
    Aug 2004
    Dubai, UAE
    well it came on a cd and i had to install it just like installing a software. then it required the indeo codec to play.
    it created an icon on desktop for "testing" and some options..like "enable dual monitor view". so I'm not really sure what's up with that.
    PS: by searching for avi, u mean regular file name search using windows??...does that work?
    maybe i'll try capturing from screen, but as u said it probably wont work.
    anymore suggestions please?
    thanx
    VERVE
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    simple search is *.avi, just to list all the files you have.
    If you are feeling adventurous, and can find the screen saver file (ends with .scr) or it's resource files (could be a .dll or similar), then follow the druid's advice and have a peek inside. You can find a tool to do this here -> http://www.angusj.com/resourcehacker/ or here -> http://www.wilsonc.demon.co.uk/d7resourceexplorer.htm
    Read my blog here.
  6. Member VERVE's Avatar
    Aug 2004
    Dubai, UAE
    I'm gonna give it a try whenever I get the chance to.
    thanx guys for the replies..u've been quite helpful...
    Cheers,
    VERVE
