I got a question on this tip. I've found in the past, x264 via Handbrake, that sometimes going constant quality can cause high 'instantaneous' bit rates. Slower computers can then choke on playback and drop a bunch of frames. Typically this problem can occur with lots of action/motion (something like sports) and/or lots of detail (something like a large school of fish). In this situation, a fixed bit rate can actually work fairly well, one would lose quality in that scene in the encode instead of dropping frames on playback.Originally Posted by major
However I usually don't really care about bit rate and 'quality' is nice way to abstract it. But I encode a lot, so I don't always have the time to review the result for the above issue. Is there a way to specify a cap for the bit rate when constant bit rate is off?
Also, what happens if I don't specify qmin=qmax with constant bit rate off? Does qmax not matter or does it somehow vary between qmin and qmax? based on what?
Thanks for the help!
Results 31 to 41 of 41
Regarding the vob. encoding to H.264 to increase quality even further, you advised me to turn on 'Print PSNR' and to look for the result value in the info doc. that comes with every encoding, to look for it at the final part. Would it be possible to be more specific? Which number to look for?
Best Regards
hito
Thanks!
Sound and video do not sync up when I convert avi to h.264 x 264.
By toddlava1 in forum ffmpegX general discussionReplies: 1Last Post: 8th Mar 2012, 02:15 -
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 04:48 -
If VHS was wider, would quality increase?
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2010, 05:25 -
Increase the bitrate---> Lose Quality?
By mark63534 in forum Newbie / General discussionsReplies: 10Last Post: 21st Jul 2010, 13:36 -
How to convert AVI to MP4 using H.264 encoder without losing video quality
By VidHunter in forum MacReplies: 0Last Post: 21st Dec 2007, 01:04
