Video source is PAL 720x576 with upper field order. I edit the video in Premiere Pro 1.5 and using procoder plugin to export to .m2v format and then encode with upper field order. After that I using Encore 1.5 to create DVD. I select don't transcode for the video source. But when I play it in DVD player the video flickering.
Actually, this problem can fix if i transcode the source again in Encore. But this is time consuming and it will lower the quality. And I tried to use lower field and no field in Premiere. Once I don't transcode in Encore flickering occurs.
Can anybody have the solution without trancode again in Encore?? Please!
Results 1 to 1 of 1
After Effects -> Premiere Pro -> Encore via Dynamic Link?
By Asterra in forum Newbie / General discussionsReplies: 4Last Post: 11th Jul 2009, 01:28 -
encode/transcode: Why use Encore rather than Premiere Pro?
By vid83 in forum Authoring (DVD)Replies: 2Last Post: 11th Jul 2008, 19:31 -
Premiere Pro/Procoder 2 to Google Video
By kippard in forum Video Streaming DownloadingReplies: 3Last Post: 16th Apr 2008, 00:03 -
Premiere Pro to Encore DVD. Export movie or Encode?
By vid83 in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2007, 05:37 -
Mov to DVD editing problem with premiere and encore
By mustafa45 in forum Video ConversionReplies: 3Last Post: 22nd Oct 2007, 08:42
