Hi ev'body!
I know this seems to be simple, but actually it is not, but why?
I am on a German system (10.4.2), but I prefer to have the English interface instaed of the German. Reason: English is more appropriate and shorter and the German translation is messy... (sorry, just my IMHO)
Right up to vs. 0.0.9s it was not problem to turn off the "not required" or in my case the "not wanted" language version by unchecking the checkbox(es).
But with FFMPEGX vs. 0.0.9t this is different, I can turn all languages off, but English and German...?
Is there any solution? Or is this due to Tiger?
Thanks!
ISSI
I do not know German so I cannot test.
Have you tried:
1. Change the UI to English (System Preferences -> International)
2. Log out and Log in
3. Get Info of ffmpegX 0.0.9t
4. See if you can uncheck German in "Languages" and leaving only English checked then.
5. Revert to German UI.
6. Log out and Log in
7. Open ffmpegX 0.0.9t and see if the menu is English
BTW, you may consider translating the menu to more appropriate German and submit to major. I believe Developers would not mind others giving positive help in the development.
Gareth
thanks for the hint, it was just what solved my problem!
...I am aware of that, and would like to help! But the main problem with the German version is, that the space in the fields, buttons etc. is sufficient for the English but not for the German. German is in many case much longer, so abbreviations reduce the quality of the GER translation. I dunno how to solve that...Originally Posted by garethhk
Major, any ideas for that?
regards
ISSI
German blu-ray problem (PAL menu?)
By hobbes4444 in forum Blu-ray RippingReplies: 0Last Post: 7th Jun 2010, 19:15 -
Converting German DVD!
By OhDoom in forum Video ConversionReplies: 13Last Post: 24th Jan 2008, 14:39 -
DVDFabDecrypter Fails On German Deja Vu?
By hech54 in forum DVD RippingReplies: 3Last Post: 13th Oct 2007, 05:19 -
Anyone here understand the German language to translate for me?
By MackemX in forum Off topicReplies: 6Last Post: 20th Jun 2007, 18:17 -
German DVD Recorder to work in USA?
By Maverik98 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th May 2007, 11:02
