    May 2005
    california
    I have some video files on my computer that are in .ogg format and i've been trying desperately for weeks to convert them somehow to a format that can be a burnt to vcd or svcd format. I dont own a dvd burner so I have to stick with vcd most of the time cause they fit on regular cd-r cd's. After reading up on it for awhile I assume that the files are another format and the audio is .ogg? When I look at the file in properties its labeled as an .ogg file but I have to use the program VSFilter (DirectVobSub) to play the files. Is there any way to accomplish burning these type of files to a cd-r? Thanks in advance.
    USA
    The audio is generally ogg and the video may be XVID or others. I save out the audio with VirtualDub as a WAV file, then convert it to AC3 or Mpeg 1, layer 2 audio. Convert the video with an encoder, then mux the audio back in. This site is a good starting source for ogg: http://en.wikipedia.org/wiki/Ogg
    Dec 2004
    Australia
    Can't have XviD in .ogg and if an ogg file had subtiles they would be in Ogg Writ format which I don't think is really working yet.
    Probably you have an ogm file with .ogg for an extension.
    May 2005
    california
    Wait, my bad. The files are dual audio ogm's. Any help with those?
    Dec 2004
    Australia
    Check the guides.
