  1. Anyone have any suggestons as to which is best for white inkjet printable dvd, and does it matter -r or +r? thanks!
    Neither of this is "best". But they're both quite decent. Best is Taiyo Yuden, Maxell, MCC.
    www.nomorecoasters.com
    As far as the inkjet surface, I have to defer to others. But I can say Prodisc printable surface is nice, while Ritek is a bit "rough".
  3. Originally Posted by Noek
    Why are you apparently limiting yourself to those two, especially considering there are better choices out there?
    In other words, why aren't you asking the question "Which is the best white inkjet printable DVD+R?"
    BTW, the answer to that question is, IMHO, 16X Verbatim MCC/Taiyo-Yuden DVD+R.
    May 2004
    WA state USA
    out of those 2 prodisc is better
  5. Based on my personal experience with these two budget brands, I would choose Ritek over Prodisc.
  6. IMO, I used Prodisc Printable (cheaper than Ritek) and I already used 250 discs with 4 bad.
    Before, I used Ritek (not printable).
  7. For white inkjet printable surface, I go with Prodisc ! Look nicer
