  1. I have a avi file i converted with winavi too dvd when i went into the folder were avi saved the file it had a disk_0 yellow folder in there were all vts files and vob files no audo folder or video_ts folder so i thought i would just burn the files with nero but when i did this the dvd won;t play on my computer or on my dvd player can any one tell me what i am doing wrong
    [/img]
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    http://members.dodo.net.au/~jimmalenko/NeroExpress.htm might help.
    You need to add all the files into a VIDEO_TS folder, and for DVD compliance you should probably include a blank AUDIO_TS folder.
    Oh, and BTW, don't forget to check out the Guides section (to your left) whenever you get stuck. Any of these should help you out:
    https://www.videohelp.com/guides.php?tools=19&madeby=&formatconversionselect=&howtosele...or+List+Guides
    If in doubt, Google it.
  3. thanks think i know were i went wrong will let you know how i went thanks for the quick reply
