Can anybody tell me if I can remove subtitles from a VCD bought in a different country [ie Japan]I can't seem to find any info on this subject Thanks
I would like to know that as well.
I've got a Laurel & Hardy VCD which has got very annoying Dutch Subtitles at the bottom.
Ne1 help at all
Thx -
No its really not possible. Vcds only support hard encoded subs, meaning the subs are actually part of the picture. There are several filters you can run to edit out the subs but the fact is that most of the time it just looks worse.
For instance the logoaway filter will take the picture surrounding the edited area and blend it in to fill the gaps. It works great on small stationary objects like logos but subtitles just come out as a huge blurred box.
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 03:51 -
bash scripts for extracting and removing subtitles from mkv files
By alidaf in forum SubtitleReplies: 0Last Post: 6th Aug 2010, 04:21 -
VCD dat files
By mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 07:50 -
Removing Subtitles from VCDs and VCD-originated MPEG and WMV files....
By dadada_999 in forum SubtitleReplies: 1Last Post: 2nd Jan 2008, 20:49 -
Extracting jpg photos from the ITEM####.dat files in the VCD segment folder
By H-Man1953 in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2007, 07:54
