I at this very moment have my Gamecube hooked up to my computer using the Belkin F5U207 USB device. Everything works fine because I tested it using the Windows Movie Maker , that's the only program I have to find out if it worked or not , silly but it worked. Can anyone here recommend a free program to use like a tv on my monitor so I can play the system. Thanks again for your help if you can provide it.
that is correct. I think the device that was recommended to me was a "vga box" not that plugs into your computer but plugs into your pc's monitor. The only problem now is finding one I guess.
Originally Posted by chriswhitelaw
Avoid connecting through the computer if gameplay is desired. The delays will make that extremely frustrating.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Easycap Video Grabber Capture card USB 2.0 RCA and S-Video?
By ffxdean in forum Capturing and VCRReplies: 149Last Post: 16th Mar 2011, 01:02 -
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 07:17 -
video capture problems - HV20 camcorder is controlled but no video capture
By chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 10:49 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 14:56 -
capture advice: USB 2.0 video capture adapter?
By j jasper in forum Capturing and VCRReplies: 10Last Post: 26th Feb 2008, 19:18
