  1. i want to buy DVD writer but now i can find three DVD writer :
    1- Lg GSA-4163B
    2- Asus DRW-1608P
    3-NEC ND 3500A
    which one is the best ? and why no body write about the asus although from the specification in this site i found that it's chipset is Nec and Oem is pioneer so it must a good writer ?
    thanks for help..........
  2. I have used the NEC and the LG and a host of other drives and I can say that the NEC is one of the best all round drives ever made when it comes to burn quality. The LG is fairly good but the NEC does a better job with quality media as well as RW. It also can be set to bitset +R discs. The Asus is just a rebadged Pioneer 109. I have one and I have been very unimpressed with the burn quality on TY and Verbatim and TDK.
    Here is a review on the Asus if you want:
    http://www.cdfreaks.com/article/220
    Still a few bugs in the system...
  3. thanks sir for your help ,
    but as i found in this forum the pioneer is a good drive and the model of NEC is older with 4X and doesn't support -RDL and asus support it so if i buy Nec i will use it for 4X DL only.
    what you suggest?
    thanks again
    waiting for reply.......
  4. If you want an NEC look around for a 3540. Its much newer. The 109 and 110 models from Pioneer are good solid burners except they have issues writing the leadout of 16x CAV media. That's the one reason I wouldn't recommend one. A lot of people also favor the Benq1620.
