Hi, I'm having burning underrruns all the time when using Nerovision Express 3. Prior to the encoding and burning, I set the burning speed to 20x (which doesn't produce underruns with the old Nero Express), but somehow it writes in 32x (one which produces underruns for some reason).
Here's the log:
[23:53:00] NeroVision Log created (Date: 08/31/2005)
[23:53:00] NeroVision Processors: 1 (Intel)
[23:53:00] NeroVision OS: Windows Windows XP
[23:53:03] GCCore Detected DirectX Version: 9.0c
[23:53:07] GCHW Node added: ACPI Fixed Feature Button
[23:53:07] GCHW Node added: Processor
[23:53:07] GCHW Node added: Programmable interrupt controller
[23:53:07] GCHW Node added: System timer
[23:53:07] GCHW Node added: Direct memory access controller
[23:53:07] GCHW Node added: Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
[23:53:07] GCHW Node added: ECP Printer Port
[23:53:07] GCHW Node added: Communications Port
[23:53:07] GCHW Node added: Standard floppy disk controller
[23:53:07] GCHW Node added: System speaker
[23:53:07] GCHW Node added: PCI bus
[23:53:07] GCHW Node added: Generic Bus
[23:53:07] GCHW Node added: System CMOS/real time clock
[23:53:07] GCHW Node added: Motherboard resources
[23:53:07] GCHW Node added: Numeric data processor
[23:53:07] GCHW Node added: ACPI Power Button
[23:53:07] GCHW Node added: PS/2 Compatible Mouse
[23:53:07] GCHW Node added: MPU-401 Compatible MIDI Device
[23:53:07] GCHW Node added: Standard Game Port
[23:53:07] GCHW Node added: Microsoft ACPI-Compliant System
[23:53:07] GCHW Node added: Intel(R) Graphics Chipset (KCH) Driver
[23:53:07] GCHW Node added: Intel(R) Graphics Platform (SoftBIOS) Driver
[23:53:07] GCHW Node added: Plug and Play Monitor
[23:53:07] GCHW Node added: Floppy disk drive
[23:53:07] GCHW Node added: CD-ROM Drive
[23:53:07] GCHW Node added: Disk drive
[23:53:07] GCHW Node added: ISAPNP Read Data Port
[23:53:07] GCHW Node added: Printer Port Logical Interface
[23:53:07] GCHW Node added: Realtek RTL8139 Family PCI Fast Ethernet NIC
[23:53:07] GCHW Node added: Conexant SoftK56 Modem(M)
[23:53:07] GCHW Node added: Intel(R) 82801DB PCI Bridge - 244E
[23:53:07] GCHW Node added: Intel(R) 82801DB LPC Interface Controller - 24C0
[23:53:07] GCHW Node added: Intel(R) 82801DB/DBM USB Universal Host Controller - 24C2
[23:53:07] GCHW Node added: Intel(R) 82801DB/DBM SMBus Controller - 24C3
[23:53:07] GCHW Node added: Intel(R) 82801DB/DBM USB Universal Host Controller - 24C4
[23:53:07] GCHW Node added: Avance AC97 Audio
[23:53:07] GCHW Node added: Intel(R) 82801DB/DBM USB Universal Host Controller - 24C7
[23:53:07] GCHW Node added: Intel(R) 82801DB Ultra ATA Storage Controller - 24CB
[23:53:07] GCHW Node added: Intel PCI to USB Enhanced Host Controller
[23:53:07] GCHW Node added: Intel(R) 82845G/GL Processor to I/O Controller 2560
[23:53:07] GCHW Node added: Intel(R) 82845G/GL Graphics Controller
[23:53:07] GCHW Node added: Primary IDE Channel
[23:53:07] GCHW Node added: Secondary IDE Channel
[23:53:07] GCHW Node added: ACPI Uniprocessor PC
[23:53:07] GCHW Node added: Volume Manager
[23:53:07] GCHW Node added: AFD Networking Support Environment
[23:53:07] GCHW Node added: ATWPKT2
[23:53:07] GCHW Node added: avgntdw
[23:53:07] GCHW Node added: Beep
[23:53:07] GCHW Node added: dmboot
[23:53:07] GCHW Node added: dmload
[23:53:07] GCHW Node added: Fips
[23:53:07] GCHW Node added: Generic Packet Classifier
[23:53:07] GCHW Node added: IPSEC driver
[23:53:07] GCHW Node added: ksecdd
[23:53:07] GCHW Node added: mdmxsdk
[23:53:07] GCHW Node added: mnmdd
[23:53:07] GCHW Node added: mountmgr
[23:53:07] GCHW Node added: NDIS System Driver
[23:53:07] GCHW Node added: Remote Access NDIS TAPI Driver
[23:53:07] GCHW Node added: NDIS Usermode I/O Protocol
[23:53:07] GCHW Node added: NDProxy
[23:53:07] GCHW Node added: NetBios over Tcpip
[23:53:07] GCHW Node added: Null
[23:53:07] GCHW Node added: PartMgr
[23:53:07] GCHW Node added: ParVdm
[23:53:07] GCHW Node added: Remote Access Auto Connection Driver
[23:53:07] GCHW Node added: RDPCDD
[23:53:07] GCHW Node added: TCP/IP Protocol Driver
[23:53:07] GCHW Node added: VgaSave
[23:53:07] GCHW Node added: VolSnap
[23:53:07] GCHW Node added: vsdatant
[23:53:07] GCHW Node added: Remote Access IP ARP Driver
[23:53:07] GCHW Node added: Audio Codecs
[23:53:07] GCHW Node added: Legacy Audio Drivers
[23:53:07] GCHW Node added: Media Control Devices
[23:53:07] GCHW Node added: Legacy Video Capture Devices
[23:53:07] GCHW Node added: Video Codecs
[23:53:07] GCHW Node added: WAN Miniport (L2TP)
[23:53:07] GCHW Node added: WAN Miniport (IP)
[23:53:07] GCHW Node added: WAN Miniport (PPPOE)
[23:53:07] GCHW Node added: WAN Miniport (PPTP)
[23:53:07] GCHW Node added: Packet Scheduler Miniport
[23:53:07] GCHW Node added: Direct Parallel
[23:53:07] GCHW Node added: WAN Miniport (ATW)
[23:53:08] GCHW Node added: PPPoEWin Miniport
[23:53:08] GCHW Node added: Terminal Server Keyboard Driver
[23:53:08] GCHW Node added: Terminal Server Mouse Driver
[23:53:08] GCHW Node added: Plug and Play Software Device Enumerator
[23:53:08] GCHW Node added: Microcode Update Device
[23:53:08] GCHW Node added: Generic volume
[23:53:08] GCHW Node added: Microsoft Kernel System Audio Device
[23:53:08] GCHW Node added: Microsoft WINMM WDM Audio Compatibility Driver
[23:53:08] GCHW Node added: USB Root Hub
[23:53:08] GCHW Node added: USB 2.0 Root Hub
[23:53:13] ExpressUI Running NeroVision Express 3 SE Version: 3.1.0.16
[23:54:30] GCHW Node added: Microsoft Kernel Wave Audio Mixer
[23:55:09] MMTools SourceBuilder: building c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 21.mpg audio/0
[23:55:10] MMTools SourceBuilder: --- used source filters ---
[23:55:10] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[23:55:10] MMTools {336475D0-942A-11CE-A870-00AA002FEAB5} - MPEG-I Stream Splitter
[23:55:10] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[23:55:10] MMTools SourceBuilder: file type unknown - audio
[23:55:10] MMTools --------------------
[23:55:10] MMTools SourceBuilder: building c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 21.mpg video/0
[23:55:10] MMTools {FEB50740-7BEF-11CE-9BD9-0000E202599C} - MPEG Video Codec
[23:55:10] MMTools SourceBuilder: file type MPEG1 - video
[23:55:27] GCCore WARNING: Operation locked for more than 15 seconds: AVGrabber (112)
[23:55:29] VCDUI VCDEngine::MPEGConverter: estimating MPEG size...
[23:55:29] VCDUI VCDEngine::MPEGConverter: estimated MPEG size: 242967228 bytes
[23:55:29] MMTools SourceBuilder: building cached c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 21.mpg video/0
[23:55:41] MMTools SourceBuilder: building c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 22 - Kuno Becomes a Marianne.mpg audio/0
[23:55:41] MMTools SourceBuilder: --- used source filters ---
[23:55:41] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[23:55:41] MMTools {336475D0-942A-11CE-A870-00AA002FEAB5} - MPEG-I Stream Splitter
[23:55:41] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[23:55:41] MMTools SourceBuilder: file type unknown - audio
[23:55:41] MMTools --------------------
[23:55:41] MMTools SourceBuilder: building c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 22 - Kuno Becomes a Marianne.mpg video/0
[23:55:41] MMTools {FEB50740-7BEF-11CE-9BD9-0000E202599C} - MPEG Video Codec
[23:55:41] MMTools SourceBuilder: file type MPEG1 - video
[23:55:57] GCCore WARNING: Operation locked for more than 15 seconds: AVGrabber (112)
[23:56:02] VCDUI VCDEngine::MPEGConverter: estimating MPEG size...
[23:56:02] VCDUI VCDEngine::MPEGConverter: estimated MPEG size: 242967228 bytes
[23:56:02] VCDUI VCDEngine::MPEGConverter: estimated MPEG size: 243071808 bytes
[23:56:02] MMTools SourceBuilder: building cached c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 22 - Kuno Becomes a Marianne.mpg video/0
[23:56:17] MMTools SourceBuilder: building c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 24.mpg audio/0
[23:56:18] MMTools SourceBuilder: --- used source filters ---
[23:56:18] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[23:56:18] MMTools {336475D0-942A-11CE-A870-00AA002FEAB5} - MPEG-I Stream Splitter
[23:56:18] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[23:56:18] MMTools SourceBuilder: file type unknown - audio
[23:56:18] MMTools --------------------
[23:56:18] MMTools SourceBuilder: building c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 24.mpg video/0
[23:56:18] MMTools {FEB50740-7BEF-11CE-9BD9-0000E202599C} - MPEG Video Codec
[23:56:18] MMTools SourceBuilder: file type MPEG1 - video
[23:56:35] VCDUI VCDEngine::MPEGConverter: estimating MPEG size...
[23:56:35] VCDUI VCDEngine::MPEGConverter: estimated MPEG size: 242967228 bytes
[23:56:35] VCDUI VCDEngine::MPEGConverter: estimated MPEG size: 243071808 bytes
[23:56:35] VCDUI VCDEngine::MPEGConverter: estimated MPEG size: 242981172 bytes
[23:56:35] MMTools SourceBuilder: building cached c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 24.mpg video/0
[23:56:42] GCCore WARNING: Operation locked for more than 15 seconds: AVGrabber (112)
[23:56:55] VCDUI VCDEngine::MPEGConverter: estimating MPEG size...
[23:56:55] VCDUI VCDEngine::MPEGConverter: estimated MPEG size: 242967228 bytes
[23:56:55] VCDUI VCDEngine::MPEGConverter: estimated MPEG size: 243071808 bytes
[23:56:55] VCDUI VCDEngine::MPEGConverter: estimated MPEG size: 242981172 bytes
[23:57:32] GCHW Node removed: Microsoft Kernel Wave Audio Mixer
[23:57:53] MMTools SourceBuilder: building cached c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 21.mpg audio/0
[23:57:53] GCHW Node added: Microsoft Kernel Wave Audio Mixer
[23:57:53] MMTools SourceBuilder: building cached c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 21.mpg video/0
[23:58:04] MMTools SourceBuilder: building cached c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 21.mpg video/0
[23:58:06] MMTools SourceBuilder: building cached c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 22 - Kuno Becomes a Marianne.mpg audio/0
[23:58:06] MMTools SourceBuilder: building cached c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 22 - Kuno Becomes a Marianne.mpg video/0
[23:58:26] MMTools SourceBuilder: building cached c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 22 - Kuno Becomes a Marianne.mpg video/0
[23:58:28] MMTools SourceBuilder: building cached c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 22 - Kuno Becomes a Marianne.mpg audio/0
[23:58:29] MMTools SourceBuilder: building cached c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 22 - Kuno Becomes a Marianne.mpg video/0
[23:58:40] MMTools SourceBuilder: building cached c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 22 - Kuno Becomes a Marianne.mpg audio/0
[23:58:40] MMTools SourceBuilder: building cached c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 22 - Kuno Becomes a Marianne.mpg video/0
[23:58:46] MMTools SourceBuilder: building cached c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 22 - Kuno Becomes a Marianne.mpg audio/0
[23:58:46] MMTools SourceBuilder: building cached c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 22 - Kuno Becomes a Marianne.mpg video/0
[23:59:44] MMTools SourceBuilder: building cached c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 22 - Kuno Becomes a Marianne.mpg video/0
[23:59:47] MMTools SourceBuilder: building cached c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 24.mpg audio/0
[23:59:48] MMTools SourceBuilder: building cached c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 24.mpg video/0
[00:00:07] MMTools SourceBuilder: building cached c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 24.mpg video/0
[00:00:25] VCDUI VCDEngine::MPEGConverter: estimating MPEG size...
[00:00:25] VCDUI VCDEngine::MPEGConverter: estimated MPEG size: 47121424 bytes
[00:00:25] VCDUI VCDEngine::MPEGConverter: estimated MPEG size: 242967228 bytes
[00:00:25] VCDUI VCDEngine::MPEGConverter: estimated MPEG size: 243071808 bytes
[00:00:25] VCDUI VCDEngine::MPEGConverter: estimated MPEG size: 242981172 bytes
[00:01:41] VCDUI VCDEngine::MPEGConverter: estimating MPEG size...
[00:01:41] VCDUI VCDEngine::MPEGConverter: estimated MPEG size: 47121424 bytes
[00:01:41] VCDUI VCDEngine::MPEGConverter: estimated MPEG size: 242969552 bytes
[00:01:41] VCDUI VCDEngine::MPEGConverter: estimated MPEG size: 243078780 bytes
[00:01:41] VCDUI VCDEngine::MPEGConverter: estimated MPEG size: 242985820 bytes
[00:02:30] ExpressUI Burn process started by user.
[00:02:30] ExpressUI Destination: SAMSUNG CDRW/DVD SM-332B
[00:02:30] ExpressUI Directory for temporary files: C:\DOCUME~1\JOEKWO~1\LOCALS~1\Temp
[00:02:30] ExpressUI Available hard disk space for temporary files: 24464.813 MB
[00:02:30] ExpressUI ------<NeroVision Project Information>--------
[00:02:30] ExpressUI --- Project type: Video CD
[00:02:30] ExpressUI --- Project video options ---
[00:02:30] ExpressUI Video mode: NTSC
[00:02:30] ExpressUI Aspect ratio: 4:3
[00:02:30] ExpressUI Quality: Custom (1150 kbps)
[00:02:30] ExpressUI Resolution: 352 x 240 (1/4 D1)
[00:02:30] ExpressUI File type: MPEG-1
[00:02:30] ExpressUI Audio format: Stereo
[00:02:30] ExpressUI Encoding mode: Fast Encoding (1-Pass)
[00:02:30] ExpressUI --- Project space information ---
[00:02:30] ExpressUI Used disc space: 654.4 MB
[00:02:30] ExpressUI --- Project contents ---
[00:02:30] ExpressUI Sample format:
[00:02:30] ExpressUI Number of titles: 3
[00:02:30] ExpressUI 1. Ranma ½ - S4 - 21 (Video Title, 0h 23m 13s)
[00:02:30] ExpressUI Audio SmartEncoding ratio: 100.0 %
[00:02:30] ExpressUI Video SmartEncoding ratio: 100.0 %
[00:02:30] ExpressUI 2. Ranma ½ - S4 - 22 - Kuno Becomes a Marianne (Video Title, 0h 23m 14s)
[00:02:30] ExpressUI 3. Ranma ½ - S4 - 24 (Video Title, 0h 23m 14s)
[00:02:30] ExpressUI Video SmartEncoding ratio: 0.0 %
[00:02:30] ExpressUI Number of menus: 1
[00:02:30] ExpressUI - Main menu (1 page)
[00:02:30] ExpressUI --------<End of Project Information>----------
[00:02:30] ExpressUI ------Recording Parameters------
[00:02:30] ExpressUI Book Type: 0
[00:02:30] ExpressUI Destination Device: SAMSUNG CDRW/DVD SM-332B (Capabilities: 00008417)
[00:02:30] ExpressUI Recording Flags: 76
[00:02:30] ExpressUI Recording Speed: 0
[00:02:30] ExpressUI Volume Name: ISLAND
[00:02:30] ExpressUI Burn-at-once flag: 0
[00:02:30] ExpressUI --End of recording parameters---
[00:02:31] VCDUI VCDEngine::MPEGConverter: estimating conversion time...
[00:02:31] VCDUI VCDEngine::MPEGConverter: estimated conversion time: 90.112000 secs
[00:02:32] VCDUI NeroMediaCon.dll: Analyze video stream
[00:02:32] VCDUI NeroMediaCon.dll: Seg. | frames | weight | volume
[00:02:32] VCDUI NeroMediaCon.dll: ------+---------+--------+--------
[00:02:32] VCDUI NeroMediaCon.dll: 0 | 41775 | 1 | 41775
[00:02:32] VCDUI NeroMediaCon.dll: total : 41775
[00:02:32] NeroAPI VCDUI: Estimating Ranma ½ - S4 - 21
[00:02:32] VCDUI VCDEngine::MPEGConverter: estimated conversion time: 450.465449 secs
[00:02:32] VCDUI VCDEngine::MPEGConverter: estimating conversion time...
[00:02:32] VCDUI NeroMediaCon.dll: 0 | 41795 | 1 | 41795
[00:02:32] VCDUI NeroMediaCon.dll: total : 41795
[00:02:32] NeroAPI VCDUI: Estimating Ranma ½ - S4 - 22 - Kuno Becomes a Marianne
[00:02:33] VCDUI VCDEngine::MPEGConverter: estimated conversion time: 395.543572 secs
[00:02:33] VCDUI VCDEngine::MPEGConverter: estimating conversion time...
[00:02:33] VCDUI NeroMediaCon.dll: Analyze video stream
[00:02:33] VCDUI NeroMediaCon.dll: Seg. | frames | weight | volume
[00:02:33] VCDUI NeroMediaCon.dll: ------+---------+--------+--------
[00:02:33] VCDUI NeroMediaCon.dll: 0 | 41780 | 1 | 41780
[00:02:33] VCDUI NeroMediaCon.dll: total : 41780
[00:02:33] MMTools SourceBuilder: building cached c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 24.mpg video/0
[00:02:33] NeroAPI VCDUI: Estimating Ranma ½ - S4 - 24
[00:02:34] VCDUI VCDEngine::MPEGConverter: estimated conversion time: 566.333566 secs
[00:02:34] VCDUI VCDEngine::MPEGConverter: estimating MPEG size...
[00:02:34] VCDUI VCDEngine::MPEGConverter: estimated MPEG size: 47121424 bytes
[00:02:34] VCDUI VCDEngine::MPEGConverter: estimated MPEG size: 242969552 bytes
[00:02:34] VCDUI VCDEngine::MPEGConverter: estimated MPEG size: 243078780 bytes
[00:02:34] VCDUI VCDEngine::MPEGConverter: estimated MPEG size: 242985820 bytes
[00:02:34] VCDUI VCDEngine::MPEGConverter: converting to MPEG (VCD)...
[00:02:34] VCDUI NeroMediaCon.dll: Temp name : C:\DOCUME~1\JOEKWO~1\LOCALS~1\Temp\NVE4.tmp
[00:02:34] VCDUI NeroMediaCon.dll: create normal resolution stream
[00:02:34] VCDUI NeroMediaCon.dll: Analyze video stream
[00:02:34] VCDUI NeroMediaCon.dll: Seg. | frames | weight | volume
[00:02:34] VCDUI NeroMediaCon.dll: ------+---------+--------+--------
[00:02:34] VCDUI NeroMediaCon.dll: 0 | 1 | 1 | 1
[00:02:34] VCDUI NeroMediaCon.dll: total : 1
[00:02:34] MMTools SourceBuilder: building c:\My Shared Folder\Ranma ½ - Ballad of Ranma and Akane.mp3 audio/0
[00:02:34] MMTools SourceBuilder: --- used source filters ---
[00:02:34] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[00:02:34] MMTools {336475D0-942A-11CE-A870-00AA002FEAB5} - MPEG-I Stream Splitter
[00:02:34] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[00:02:34] MMTools SourceBuilder: file type unknown - audio
[00:02:34] MMTools --------------------
[00:02:34] NeroAPI VCDUI: Transcoding Menu 1
[00:03:01] VCDUI NeroMediaCon.dll: Analyze video stream
[00:03:01] VCDUI NeroMediaCon.dll: Seg. | frames | weight | volume
[00:03:01] VCDUI NeroMediaCon.dll: ------+---------+--------+--------
[00:03:01] VCDUI NeroMediaCon.dll: 0 | 1 | 1 | 1
[00:03:01] VCDUI NeroMediaCon.dll: total : 1
[00:03:01] MMTools SourceBuilder: building cached c:\My Shared Folder\Ranma ½ - Ballad of Ranma and Akane.mp3 audio/0
[00:03:28] GCHW Node removed: Microsoft Kernel Wave Audio Mixer
[00:03:30] VCDUI VCDEngine::MPEGConverter: converting to MPEG done: size=20311 sectors, playtime=0 CD-frames (0.000000 secs)
[00:03:30] VCDUI VCDEngine::MPEGConverter: converting to MPEG (VCD)...
[00:03:30] VCDUI NeroMediaCon.dll: Analyze video stream
[00:03:30] VCDUI NeroMediaCon.dll: Seg. | frames | weight | volume
[00:03:30] VCDUI NeroMediaCon.dll: ------+---------+--------+--------
[00:03:30] VCDUI NeroMediaCon.dll: 0 | 41775 | 1 | 41775
[00:03:30] VCDUI NeroMediaCon.dll: total : 41775
[00:03:30] VCDUI NeroMediaCon.dll: Set Preview Channel
[00:03:31] NeroAPI VCDUI: Transcoding Ranma ½ - S4 - 21
[00:04:24] VCDUI VCDEngine::MPEGConverter: converting to MPEG done: size=104573 sectors, playtime=104545 CD-frames (1393.933333 secs)
[00:04:24] VCDUI VCDEngine::MPEGConverter: converting to MPEG (VCD)...
[00:04:24] VCDUI NeroMediaCon.dll: Analyze video stream
[00:04:24] VCDUI NeroMediaCon.dll: Seg. | frames | weight | volume
[00:04:24] VCDUI NeroMediaCon.dll: ------+---------+--------+--------
[00:04:24] VCDUI NeroMediaCon.dll: 0 | 41795 | 1 | 41795
[00:04:24] VCDUI NeroMediaCon.dll: total : 41795
[00:04:24] VCDUI NeroMediaCon.dll: Set Preview Channel
[00:04:25] NeroAPI VCDUI: Transcoding Ranma ½ - S4 - 22 - Kuno Becomes a Marianne
[00:05:37] VCDUI VCDEngine::MPEGConverter: converting to MPEG done: size=104622 sectors, playtime=104592 CD-frames (1394.560000 secs)
[00:05:37] VCDUI VCDEngine::MPEGConverter: converting to MPEG (VCD)...
[00:05:37] VCDUI NeroMediaCon.dll: Analyze video stream
[00:05:37] VCDUI NeroMediaCon.dll: Seg. | frames | weight | volume
[00:05:37] VCDUI NeroMediaCon.dll: ------+---------+--------+--------
[00:05:37] VCDUI NeroMediaCon.dll: 0 | 41780 | 1 | 41780
[00:05:37] VCDUI NeroMediaCon.dll: total : 41780
[00:05:37] VCDUI NeroMediaCon.dll: Set Preview Channel
[00:05:37] MMTools SourceBuilder: building cached c:\Program Files\eMule\Incoming\Ranma ½ - S4 - 24.mpg video/0
[00:05:38] NeroAPI VCDUI: Transcoding Ranma ½ - S4 - 24
[00:14:02] VCDUI VCDEngine::MPEGConverter: converting to MPEG done: size=104581 sectors, playtime=104552 CD-frames (1394.026667 secs)
[00:14:45] NeroAPI Video MPEG encoder not available
[00:14:46] NeroAPI Caching of files started
[00:14:46] NeroAPI Caching of files completed
[00:14:46] NeroAPI Burn process started at 32x (4,800 KB/s)
[00:16:47] NeroAPI Invalid field in command
[00:16:47] NeroAPI Burn process failed at 32x (4,800 KB/s)
[00:16:52] NeroVision Process information:
[00:16:52] NeroVision --------------------
[00:16:52] NeroVision Address Version Module name
[00:16:52] NeroVision -----------------------------------------------------
[00:16:52] NeroVision 0x00330000 3.1.0.16 C:\Program Files\Ahead\NeroVision\GCLib.dll
[00:16:52] NeroVision 0x003C0000 3.1.0.16 C:\Program Files\Ahead\NeroVision\GDIPainter.dll
[00:16:52] NeroVision 0x003D0000 3.1.0.16 C:\Program Files\Ahead\NeroVision\AMCLib.dll
[00:16:52] NeroVision 0x003E0000 3.1.0.16 C:\Program Files\Ahead\NeroVision\AMCDOM.dll
[00:16:52] NeroVision 0x00400000 3.1.0.16 C:\Program Files\Ahead\NeroVision\NeroVision.exe
[00:16:52] NeroVision 0x00470000 3.1.0.16 C:\Program Files\Ahead\NeroVision\AMCUIBase.dll
[00:16:52] NeroVision 0x006A0000 3.1.0.16 C:\Program Files\Ahead\NeroVision\GCCore.dll
[00:16:52] NeroVision 0x00720000 3.1.0.16 C:\Program Files\Ahead\NeroVision\AMCDocBase.dll
[00:16:52] NeroVision 0x008D0000 3.1.0.16 C:\Program Files\Ahead\NeroVision\MMTools.dll
[00:16:52] NeroVision 0x012C0000 7.0.46.0 C:\WINDOWS\System32\ImagXpr7.dll
[00:16:52] NeroVision 0x01340000 7.0.46.0 C:\WINDOWS\System32\ImagX7.dll
[00:16:52] NeroVision 0x01560000 7.0.476.0 C:\WINDOWS\System32\ImagXR7.dll
[00:16:52] NeroVision 0x01670000 3.1.0.16 C:\Program Files\Ahead\NeroVision\GCFX.DLL
[00:16:52] NeroVision 0x01A60000 1.1.0.865 C:\Program Files\Ahead\NeroVision\NeVideoFX.dll
[00:16:52] NeroVision 0x01CD0000 1.0.0.3 C:\Program Files\Ahead\NeroVision\NeVideoFX.bitmaps
[00:16:52] NeroVision 0x02480000 1.0.1.12 C:\Program Files\Ahead\NeroVision\NeVideoFXW.dll
[00:16:52] NeroVision 0x025C0000 1.2.10.2305 C:\Program Files\Common Files\Ahead\Lib\AdvrCntr.dll
[00:16:52] NeroVision 0x028C0000 6.5.1.900 C:\WINDOWS\System32\msdmo.dll
[00:16:52] NeroVision 0x028E0000 5.3.1.904 C:\WINDOWS\System32\dxdiagn.dll
[00:16:52] NeroVision 0x02FA0000 3.1.0.16 C:\Program Files\Ahead\NeroVision\GCHW.DLL
[00:16:52] NeroVision 0x03750000 6.6.0.16 C:\Program Files\Ahead\NeroVision\NeroFiles\NeroAPI.DLL
[00:16:52] NeroVision 0x04380000 2.0.2.13 C:\Program Files\Ahead\NeroVision\NeroFiles\NeRSDB.dll
[00:16:52] NeroVision 0x04630000 1.0.0.17 C:\Program Files\Common Files\Ahead\Lib\DriveLocker.dll
[00:16:52] NeroVision 0x04AD0000 3.1.0.16 C:\Program Files\Ahead\NeroVision\ExpressUI.dll
[00:16:52] NeroVision 0x04EC0000 3.1.0.16 C:\Program Files\Ahead\NeroVision\GCHWCfg.dll
[00:16:52] NeroVision 0x04EE0000 3.1.0.16 C:\Program Files\Ahead\NeroVision\GCLocale.dll
[00:16:52] NeroVision 0x04EF0000 3.1.0.16 C:\Program Files\Ahead\NeroVision\ExpressDoc.dll
[00:16:52] NeroVision 0x05860000 3.1.0.16 C:\Program Files\Ahead\NeroVision\VCDUI.dll
[00:16:52] NeroVision 0x05890000 3.1.0.16 C:\Program Files\Ahead\NeroVision\VCDDoc.dll
[00:16:52] NeroVision 0x058B0000 3.1.0.16 C:\Program Files\Ahead\NeroVision\VCDEngine.dll
[00:16:52] NeroVision 0x058D0000 2.0.0.36 C:\Program Files\Ahead\NeroVision\NeroMediaCon.dll
[00:16:52] NeroVision 0x06210000 3.1.0.16 C:\Program Files\Ahead\NeroVision\GCCapture.ax
[00:16:52] NeroVision 0x06250000 3.1.0.16 C:\Program Files\Ahead\NeroVision\GCFilter.ax
[00:16:52] NeroVision 0x062F0000 1.0.4.65 C:\Program Files\Common Files\Ahead\DSFilter\NeAudio.ax
[00:16:52] NeroVision 0x06AB0000 5.2.1.1335 C:\WINDOWS\System32\divxdec.ax
[00:16:52] NeroVision 0x06C90000 9.0.0.2980 C:\WINDOWS\System32\WMASF.DLL
[00:16:52] NeroVision 0x06CD0000 1.0.4.6 C:\Program Files\Common Files\Ahead\DSFilter\NeFSource.ax
[00:16:52] NeroVision 0x06E40000 1.0.1.9 C:\Program Files\Common Files\Ahead\DSFilter\NeRender.ax
[00:16:52] NeroVision 0x075A0000 1.0.0.4 C:\Program Files\Common Files\Ahead\DSFilter\NeResize.ax
[00:16:52] NeroVision 0x075C0000 1.0.0.77 C:\Program Files\Common Files\Ahead\DSFilter\NeroVideoProc.ax
[00:16:52] NeroVision 0x075F0000 2.0.0.2 C:\Program Files\Common Files\Ahead\DSFilter\NeroFormatConv.ax
[00:16:52] NeroVision 0x08460000 1.2.0.6 C:\Program Files\Common Files\Ahead\DSFilter\NeAudioConv.ax
[00:16:52] NeroVision 0x08530000 9.0.0.2980 C:\WINDOWS\System32\wmvcore.dll
[00:16:52] NeroVision 0x089F0000 9.0.0.2980 C:\WINDOWS\System32\qasf.dll
[00:16:52] NeroVision 0x10000000 5.9.9.5 C:\Program Files\Ahead\NeroVision\HDCC.dll
[00:16:52] NeroVision 0x13000000 2.0.1.74 C:\Program Files\Ahead\NeroVision\NeroFiles\WNASPI32.Dll
[00:16:52] NeroVision 0x15000000 6.6.0.16 C:\Program Files\Ahead\NeroVision\NeroFiles\image.dll
[00:16:52] NeroVision 0x19000000 6.6.0.16 C:\Program Files\Ahead\NeroVision\NeroFiles\MMC.DLL
[00:16:52] NeroVision 0x1C200000 6.5.1.900 C:\WINDOWS\System32\qedit.dll
[00:16:52] NeroVision 0x1C400000 0.4.0.0 C:\WINDOWS\system32\DivXAF.ax
[00:16:52] NeroVision 0x1FF00000 6.5.1.900 C:\WINDOWS\System32\mpg2splt.ax
[00:16:52] NeroVision 0x20000000 6.6.0.16 C:\Program Files\Ahead\NeroVision\NeroFiles\NeroErr.dll
[00:16:52] NeroVision 0x21000000 6.6.0.16 C:\Program Files\Ahead\NeroVision\NeroFiles\neroscsi.dll
[00:16:52] NeroVision 0x22000000 6.6.0.16 C:\Program Files\Ahead\NeroVision\NeroFiles\newtrf.dll
[00:16:52] NeroVision 0x35500000 6.5.1.902 C:\WINDOWS\System32\QUARTZ.dll
[00:16:52] NeroVision 0x35680000 6.5.1.902 C:\WINDOWS\System32\devenum.dll
[00:16:52] NeroVision 0x51000000 5.3.1.904 C:\WINDOWS\System32\DDRAW.dll
[00:16:52] NeroVision 0x51080000 5.3.1.904 C:\WINDOWS\System32\dsound.dll
[00:16:52] NeroVision 0x52880000 5.1.2600.15 C:\WINDOWS\system32\USERENV.dll
[00:16:52] NeroVision 0x5AD70000 6.0.2600.0 C:\WINDOWS\System32\UxTheme.dll
[00:16:52] NeroVision 0x5C000000 5.3.1.902 C:\WINDOWS\System32\D3DIM700.DLL
[00:16:52] NeroVision 0x5CAD0000 6.0.2600.0 C:\WINDOWS\System32\shmedia.dll
[00:16:52] NeroVision 0x5E760000 5.1.2600.0 C:\WINDOWS\System32\perfos.dll
[00:16:52] NeroVision 0x5EDD0000 3.50.5014.0 C:\WINDOWS\System32\OLEPRO32.DLL
[00:16:52] NeroVision 0x5EF80000 5.3.0.900 C:\WINDOWS\System32\KsUser.dll
[00:16:52] NeroVision 0x629C0000 5.1.2600.0 C:\WINDOWS\System32\LPK.DLL
[00:16:52] NeroVision 0x69B10000 4.10.9404.0 C:\WINDOWS\System32\msxml4.dll
[00:16:52] NeroVision 0x70D00000 5.1.3097.0 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_65 95b64144ccf1df_1.0.0.0_x-ww_8d353f13\gdiplus.dll
[00:16:52] NeroVision 0x71950000 6.0.2600.0 C:\WINDOWS\WinSxS\X86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.0.0_x-ww_1382d70a\COMCTL32.dll
[00:16:52] NeroVision 0x71AA0000 5.1.2600.0 C:\WINDOWS\System32\WS2HELP.dll
[00:16:52] NeroVision 0x71AB0000 5.1.2600.0 C:\WINDOWS\System32\WS2_32.dll
[00:16:52] NeroVision 0x71AD0000 5.1.2600.0 C:\WINDOWS\System32\wsock32.dll
[00:16:52] NeroVision 0x71C20000 5.1.2600.0 C:\WINDOWS\System32\NETAPI32.dll
[00:16:52] NeroVision 0x72D10000 5.1.2600.0 C:\WINDOWS\System32\msacm32.drv
[00:16:52] NeroVision 0x72D20000 5.1.2600.0 C:\WINDOWS\System32\wdmaud.drv
[00:16:52] NeroVision 0x72FA0000 1.407.2600.0 C:\WINDOWS\System32\USP10.dll
[00:16:52] NeroVision 0x73000000 5.1.2600.0 C:\WINDOWS\System32\WINSPOOL.DRV
[00:16:52] NeroVision 0x732E0000 5.1.2600.0 C:\WINDOWS\System32\RICHED32.DLL
[00:16:52] NeroVision 0x73B50000 5.1.2600.0 C:\WINDOWS\System32\AVIFIL32.dll
[00:16:52] NeroVision 0x73BC0000 5.1.2600.0 C:\WINDOWS\System32\DCIMAN32.dll
[00:16:52] NeroVision 0x73BD0000 5.1.2600.0 C:\WINDOWS\System32\MSVFW32.dll
[00:16:52] NeroVision 0x73DD0000 6.0.4.0 C:\WINDOWS\System32\MFC42.DLL
[00:16:52] NeroVision 0x74770000 6.0.2600.0 C:\WINDOWS\System32\mlang.dll
[00:16:52] NeroVision 0x74AD0000 6.0.2600.0 C:\WINDOWS\System32\POWRPROF.dll
[00:16:52] NeroVision 0x74D30000 5.1.2600.0 C:\WINDOWS\System32\oledlg.dll
[00:16:52] NeroVision 0x74E30000 5.0.0.0 C:\WINDOWS\System32\RICHED20.dll
[00:16:52] NeroVision 0x74ED0000 5.1.2600.0 C:\WINDOWS\System32\wbem\wbemsvc.dll
[00:16:52] NeroVision 0x74EF0000 5.1.2600.0 C:\WINDOWS\System32\wbem\wbemprox.dll
[00:16:52] NeroVision 0x75290000 5.1.2600.0 C:\WINDOWS\System32\wbem\wbemcomn.dll
[00:16:52] NeroVision 0x75690000 5.1.2600.0 C:\WINDOWS\System32\wbem\fastprox.dll
[00:16:52] NeroVision 0x75F40000 5.1.2600.0 C:\WINDOWS\system32\appHelp.dll
[00:16:52] NeroVision 0x75F80000 6.0.2600.0 C:\WINDOWS\System32\browseui.dll
[00:16:52] NeroVision 0x76200000 6.0.2600.0 C:\WINDOWS\system32\WININET.dll
[00:16:52] NeroVision 0x762A0000 5.1.2600.0 C:\WINDOWS\system32\MSASN1.dll
[00:16:52] NeroVision 0x762C0000 5.131.2600.0 C:\WINDOWS\system32\CRYPT32.dll
[00:16:52] NeroVision 0x76380000 5.1.2600.0 C:\WINDOWS\System32\MSIMG32.dll
[00:16:52] NeroVision 0x76390000 5.1.2600.0 C:\WINDOWS\System32\IMM32.DLL
[00:16:52] NeroVision 0x763B0000 6.0.2600.0 C:\WINDOWS\system32\comdlg32.dll
[00:16:52] NeroVision 0x76600000 5.1.2600.0 C:\WINDOWS\System32\CSCDLL.dll
[00:16:52] NeroVision 0x76620000 5.1.2600.0 C:\WINDOWS\System32\cscui.dll
[00:16:52] NeroVision 0x76670000 5.1.2600.0 C:\WINDOWS\System32\SETUPAPI.dll
[00:16:52] NeroVision 0x76990000 5.1.2600.0 C:\WINDOWS\System32\ntshrui.dll
[00:16:52] NeroVision 0x769C0000 6.0.2600.0 C:\WINDOWS\System32\shdocvw.dll
[00:16:52] NeroVision 0x76B20000 6.0.0.9238 C:\WINDOWS\System32\ATL.DLL
[00:16:52] NeroVision 0x76B40000 5.1.2600.0 C:\WINDOWS\System32\WINMM.dll
[00:16:52] NeroVision 0x76FD0000 3.0.0.4414 C:\WINDOWS\System32\CLBCATQ.DLL
[00:16:52] NeroVision 0x77050000 3.0.0.4414 C:\WINDOWS\System32\COMRes.dll
[00:16:52] NeroVision 0x77120000 3.50.5014.0 C:\WINDOWS\system32\OLEAUT32.dll
[00:16:52] NeroVision 0x771B0000 5.1.2600.0 C:\WINDOWS\system32\ole32.dll
[00:16:52] NeroVision 0x772D0000 6.0.2600.0 C:\WINDOWS\system32\SHLWAPI.dll
[00:16:52] NeroVision 0x773D0000 6.0.2600.0 C:\WINDOWS\system32\SHELL32.dll
[00:16:52] NeroVision 0x77BD0000 5.1.2600.0 C:\WINDOWS\System32\midimap.dll
[00:16:52] NeroVision 0x77BE0000 5.1.2600.0 C:\WINDOWS\System32\MSACM32.dll
[00:16:52] NeroVision 0x77C00000 5.1.2600.0 C:\WINDOWS\system32\VERSION.dll
[00:16:52] NeroVision 0x77C10000 6.1.8638.0 C:\WINDOWS\system32\MSVCRT.DLL
[00:16:52] NeroVision 0x77C70000 5.1.2600.0 C:\WINDOWS\system32\GDI32.dll
[00:16:52] NeroVision 0x77CC0000 5.1.2600.0 C:\WINDOWS\system32\RPCRT4.dll
[00:16:52] NeroVision 0x77D40000 5.1.2600.0 C:\WINDOWS\system32\USER32.dll
[00:16:52] NeroVision 0x77DD0000 5.1.2600.0 C:\WINDOWS\system32\ADVAPI32.dll
[00:16:52] NeroVision 0x77E60000 5.1.2600.0 C:\WINDOWS\system32\kernel32.dll
[00:16:52] NeroVision 0x77F50000 5.1.2600.0 C:\WINDOWS\System32\ntdll.dll
[00:16:52] NeroVision 0x780C0000 6.0.8972.0 C:\Program Files\Ahead\NeroVision\MSVCP60.dll
[00:16:52] NeroVision Book type: (N/A)
[00:16:52] NeroVision Properties of your project:
[00:16:52] NeroVision Aspect ratio: 4:3
[00:16:52] NeroVision Video mode: NTSC
[00:16:52] NeroVision Used disc space: 654.4 MB
[00:16:52] NeroVision Your project contains the following:
[00:16:52] NeroVision Sample format:
[00:16:52] NeroVision Audio format: Stereo
[00:16:52] NeroVision Encoding mode: Fast Encoding (1-Pass)
[00:16:52] NeroVision Number of titles: 3
[00:16:52] NeroVision 1. Ranma ½ - S4 - 21 (Video Title, 0h 23m 13s)
[00:16:52] NeroVision Quality: Custom (1150 kbps)
[00:16:52] NeroVision Resolution: 352 x 240 (1/4 D1)
[00:16:52] NeroVision Audio SmartEncoding ratio: 100.0 %
[00:16:52] NeroVision Video SmartEncoding ratio: 100.0 %
[00:16:52] NeroVision 2. Ranma ½ - S4 - 22 - Kuno Becomes a Marianne (Video Title, 0h 23m 14s)
[00:16:52] NeroVision 3. Ranma ½ - S4 - 24 (Video Title, 0h 23m 14s)
[00:16:52] NeroVision Video SmartEncoding ratio: 0.0 %
[00:16:52] NeroVision Number of menus: 1
[00:16:52] NeroVision - Main menu (1 page)VCDEngine::MPEGConverter: estimating conversion time...
[00:16:52] NeroVision VCDEngine::MPEGConverter: estimated conversion time: 90.112000 secs
[00:16:52] NeroVision VCDEngine::MPEGConverter: estimating conversion time...
[00:16:52] NeroVision NeroMediaCon.dll: Analyze video stream
[00:16:52] NeroVision NeroMediaCon.dll: Seg. | frames | weight | volume
[00:16:52] NeroVision NeroMediaCon.dll: ------+---------+--------+--------
[00:16:52] NeroVision NeroMediaCon.dll: 0 | 41775 | 1 | 41775
[00:16:52] NeroVision NeroMediaCon.dll: total : 41775
[00:16:52] NeroVision VCDEngine::MPEGConverter: estimated conversion time: 450.465449 secs
[00:16:52] NeroVision NeroMediaCon.dll: 0 | 41795 | 1 | 41795
[00:16:52] NeroVision NeroMediaCon.dll: total : 41795
[00:16:52] NeroVision VCDEngine::MPEGConverter: estimated conversion time: 395.543572 secs
[00:16:52] NeroVision NeroMediaCon.dll: 0 | 41780 | 1 | 41780
[00:16:52] NeroVision NeroMediaCon.dll: total : 41780
[00:16:52] NeroVision VCDEngine::MPEGConverter: estimated conversion time: 566.333566 secs
[00:16:52] NeroVision VCDEngine::MPEGConverter: estimating MPEG size...
[00:16:52] NeroVision VCDEngine::MPEGConverter: estimated MPEG size: 47121424 bytes
[00:16:52] NeroVision VCDEngine::MPEGConverter: estimated MPEG size: 242969552 bytes
[00:16:52] NeroVision VCDEngine::MPEGConverter: estimated MPEG size: 243078780 bytes
[00:16:52] NeroVision VCDEngine::MPEGConverter: estimated MPEG size: 242985820 bytes
[00:16:52] NeroVision VCDEngine::MPEGConverter: converting to MPEG (VCD)...
[00:16:52] NeroVision NeroMediaCon.dll: Temp name : C:\DOCUME~1\JOEKWO~1\LOCALS~1\Temp\NVE4.tmp
[00:16:52] NeroVision NeroMediaCon.dll: create normal resolution stream
[00:16:52] NeroVision NeroMediaCon.dll: 0 | 1 | 1 | 1
[00:16:52] NeroVision NeroMediaCon.dll: total : 1
[00:16:52] NeroVision VCDEngine::MPEGConverter: converting to MPEG done: size=20311 sectors, playtime=0 CD-frames (0.000000 secs)
[00:16:52] NeroVision NeroMediaCon.dll: Set Preview Channel
[00:16:52] NeroVision VCDEngine::MPEGConverter: converting to MPEG done: size=104573 sectors, playtime=104545 CD-frames (1393.933333 secs)
[00:16:52] NeroVision VCDEngine::MPEGConverter: converting to MPEG done: size=104622 sectors, playtime=104592 CD-frames (1394.560000 secs)
[00:16:52] NeroVision VCDEngine::MPEGConverter: converting to MPEG done: size=104581 sectors, playtime=104552 CD-frames (1394.026667 secs)
[00:16:52] NeroVision 1A20-020E-0000-1349-1210-6697*
[00:16:52] NeroVision Windows XP 5.1
[00:16:52] NeroVision IA32
[00:16:52] NeroVision WinAspi: -
[00:16:52] NeroVision ahead WinASPI: File 'C:\Program Files\Ahead\NeroVision\NeroFiles\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 18:35:34
[00:16:52] NeroVision Nero API version: 6.6.0.16
[00:16:52] NeroVision Using interface version: 6.6.0.10
[00:16:52] NeroVision Installed in: C:\Program Files\Ahead\NeroVision\NeroFiles\
[00:16:52] NeroVision Application: ahead\NeroVision
[00:16:52] NeroVision Internal Version: 6, 6, 0, 16b
[00:16:52] NeroVision Recorder: <SAMSUNG CDRW/DVD SM-332B>Version: T400 - HA 1 TA 0 - 6.6.0.16
[00:16:52] NeroVision Adapter driver: <atapi> HA 1
[00:16:52] NeroVision Drive buffer : 8192kB
[00:16:52] NeroVision Bus Type : default (0) -> ATAPI, detected: ATAPI
[00:16:52] NeroVision === Scsi-Device-Map ===
[00:16:52] NeroVision DiskPeripheral : Maxtor 4D060H3 atapi Port 0 ID 0 DMA: On
[00:16:52] NeroVision CdRomPeripheral : SAMSUNG CDRW/DVD SM-332B atapi Port 1 ID 0 DMA: On
[00:16:52] NeroVision === CDRom-Device-Map ===
[00:16:52] NeroVision SAMSUNG CDRW/DVD SM-332B D: CDRom0
[00:16:52] NeroVision =======================
[00:16:52] NeroVision AutoRun : 1
[00:16:52] NeroVision Excluded drive IDs:
[00:16:52] NeroVision WriteBufferSize: 40894464 (0) Byte
[00:16:52] NeroVision ShowDrvBufStat : 0
[00:16:52] NeroVision BUFE : 0
[00:16:52] NeroVision Physical memory : 253MB (260080kB)
[00:16:52] NeroVision Free physical memory: 102MB (104556kB)
[00:16:52] NeroVision Memory in use : 59 %
[00:16:52] NeroVision Uncached PFiles: 0x0
[00:16:52] NeroVision Use Inquiry : 1
[00:16:52] NeroVision Global Bus Type: default (0)
[00:16:52] NeroVision Check supported media : Disabled (0)
[00:16:52] NeroVision 1.9.2005
[00:16:52] NeroVision NeroAPI
[00:16:52] NeroVision 00:14:08 #1 AVIVCDFILEITEM -100 File AVIVCDFileItem.cpp, Line 435
[00:16:52] NeroVision Video MPEG encoder not available
[00:16:52] NeroVision 00:14:22 #2 AVIVCDFILEITEM -100 File AVIVCDFileItem.cpp, Line 435
[00:16:52] NeroVision 00:14:35 #3 AVIVCDFILEITEM -100 File AVIVCDFileItem.cpp, Line 435
[00:16:52] NeroVision 00:14:45 #4 Text 0 File Reader.cpp, Line 127
[00:16:52] NeroVision Reader running
[00:16:52] NeroVision 00:14:45 #5 Text 0 File Writer.cpp, Line 122
[00:16:52] NeroVision Writer SAMSUNG CDRW/DVD SM-332B running
[00:16:52] NeroVision 00:14:45 #6 ISO9660GEN -11 File geniso.cpp, Line 3309
[00:16:52] NeroVision First writeable address = 0 (0x00000000)
[00:16:52] NeroVision 00:14:45 #7 ISO9660GEN -11 File geniso.cpp, Line 3309
[00:16:52] NeroVision 00:14:45 #8 Text 0 File Burncd.cpp, Line 3233
[00:16:52] NeroVision Turn on Disc-At-Once, using CD-R/RW media
[00:16:52] NeroVision 00:14:45 #9 Text 0 File DlgWaitCD.cpp, Line 270
[00:16:52] NeroVision Last possible write address on media: 359846 ( 79:59.71)
[00:16:52] NeroVision Last address to be written: 336046 ( 74:42.46)
[00:16:52] NeroVision 00:14:45 #10 Text 0 File DlgWaitCD.cpp, Line 282
[00:16:52] NeroVision Write in overburning mode: NO (enabled: CD)
[00:16:52] NeroVision 00:14:45 #11 Text 0 File DlgWaitCD.cpp, Line 2483
[00:16:52] NeroVision Recorder: SAMSUNG CDRW/DVD SM-332B;
[00:16:52] NeroVision CDR code: 00 97 24 01; OSJ entry from: Taiyo Yuden Company Limited
[00:16:52] NeroVision ATIP Data:
[00:16:52] NeroVision Special Info [hex] 1: C0 00 98, 2: 61 18 01 (LI 97:24.01), 3: 4F 3B 48 (LO 79:59.72)
[00:16:52] NeroVision Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
[00:16:52] NeroVision 00:14:45 #12 Text 0 File DlgWaitCD.cpp, Line 448
[00:16:52] NeroVision >>> Protocol of DlgWaitCD activities: <<<
[00:16:52] NeroVision =========================================
[00:16:52] NeroVision 00:14:45 #13 Text 0 File ThreadedTransferInterface.cpp, Line 838
[00:16:52] NeroVision Setup items (after recorder preparation)
[00:16:52] NeroVision 0: TRM_DATA_MODE2_2336 ()
[00:16:52] NeroVision 2 indices, index0 (150) not provided
[00:16:52] NeroVision original disc pos #0 + 21551 (21551) = #21551/4:47.26
[00:16:52] NeroVision relocatable, disc pos for caching/writing not required/ required, no patch infos
[00:16:52] NeroVision -> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 21551 blocks [SAMSUNG CDRW/DVD SM-332B]
[00:16:52] NeroVision 1: TRM_DATA_MODE2_2336 (NVE5)
[00:16:52] NeroVision original disc pos #0 + 104663 (104663) = #104663/23:15.38
[00:16:52] NeroVision relocatable, disc pos for caching/writing not required/not required, no patch infos
[00:16:52] NeroVision -> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 104663 blocks [SAMSUNG CDRW/DVD SM-332B]
[00:16:52] NeroVision 2: TRM_DATA_MODE2_2336 (NVE6)
[00:16:52] NeroVision original disc pos #0 + 104712 (104712) = #104712/23:16.12
[00:16:52] NeroVision -> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 104712 blocks [SAMSUNG CDRW/DVD SM-332B]
[00:16:52] NeroVision 3: TRM_DATA_MODE2_2336 (NVE7)
[00:16:52] NeroVision original disc pos #0 + 104671 (104671) = #104671/23:15.46
[00:16:52] NeroVision -> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 104671 blocks [SAMSUNG CDRW/DVD SM-332B]
[00:16:52] NeroVision --------------------------------------------------------------
[00:16:52] NeroVision 00:14:45 #14 Text 0 File ThreadedTransferInterface.cpp, Line 1051
[00:16:52] NeroVision Prepare recorder [SAMSUNG CDRW/DVD SM-332B] for write in CUE-sheet-DAO
[00:16:52] NeroVision DAO infos:
[00:16:52] NeroVision MCN: ""
[00:16:52] NeroVision TOCType: 0x20; Session Closed, disc fixated
[00:16:52] NeroVision Tracks 1 to 4:
[00:16:52] NeroVision 1: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 0 352800 51040752, ISRC ""
[00:16:52] NeroVision 2: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 51040752 51393552 297560928, ISRC ""
[00:16:52] NeroVision 3: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 297560928 297913728 544196352, ISRC ""
[00:16:52] NeroVision 4: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 544196352 544549152 790735344, ISRC ""
[00:16:52] NeroVision DAO layout:
[00:16:52] NeroVision __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
[00:16:52] NeroVision -150 | lead-in | 0 | 0x41 | 0x00
[00:16:52] NeroVision -150 | 1 | 0 | 0x41 | 0x00
[00:16:52] NeroVision 0 | 1 | 1 | 0x41 | 0x00
[00:16:52] NeroVision 21551 | 2 | 0 | 0x41 | 0x00
[00:16:52] NeroVision 21701 | 2 | 1 | 0x41 | 0x00
[00:16:52] NeroVision 126364 | 3 | 0 | 0x41 | 0x00
[00:16:52] NeroVision 126514 | 3 | 1 | 0x41 | 0x00
[00:16:52] NeroVision 231226 | 4 | 0 | 0x41 | 0x00
[00:16:52] NeroVision 231376 | 4 | 1 | 0x41 | 0x00
[00:16:52] NeroVision 336047 | lead-out | 1 | 0x41 | 0x00
[00:16:52] NeroVision 00:14:46 #15 Phase 24 File APIProgress.cpp, Line 276
[00:16:52] NeroVision Caching of files started
[00:16:52] NeroVision 00:14:46 #16 Text 0 File Burncd.cpp, Line 4120
[00:16:52] NeroVision Cache writing successful.
[00:16:52] NeroVision 00:14:46 #17 Phase 25 File APIProgress.cpp, Line 276
[00:16:52] NeroVision Caching of files completed
[00:16:52] NeroVision 00:14:46 #18 Phase 36 File APIProgress.cpp, Line 276
[00:16:52] NeroVision Burn process started at 32x (4,800 KB/s)
[00:16:52] NeroVision 00:14:46 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2654
[00:16:52] NeroVision Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
[00:16:52] NeroVision 00:14:46 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2654
[00:16:52] NeroVision Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #21701
[00:16:52] NeroVision 00:14:46 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2654
[00:16:52] NeroVision Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #126514
[00:16:52] NeroVision 00:14:46 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2654
[00:16:52] NeroVision Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #231376
[00:16:52] NeroVision 00:14:46 #23 Text 0 File Mmc.cpp, Line 16924
[00:16:52] NeroVision StartDAO : CD-Text - Off
[00:16:52] NeroVision 00:14:46 #24 Text 0 File Mmc.cpp, Line 21708
[00:16:52] NeroVision Set BUFE: JustLink -> ON
[00:16:52] NeroVision 00:14:46 #25 Text 0 File Mmc.cpp, Line 17211
[00:16:52] NeroVision CueData, Len=80
[00:16:52] NeroVision 41 00 00 34 00 00 00 00
[00:16:52] NeroVision 41 01 00 21 00 00 00 00
[00:16:52] NeroVision 41 01 01 21 00 00 02 00
[00:16:52] NeroVision 41 02 00 21 00 04 31 1a
[00:16:52] NeroVision 41 02 01 21 00 04 33 1a
[00:16:52] NeroVision 41 03 00 21 00 1c 06 40
[00:16:52] NeroVision 41 03 01 21 00 1c 08 40
[00:16:52] NeroVision 41 04 00 21 00 33 19 01
[00:16:52] NeroVision 41 04 01 21 00 33 1b 01
[00:16:52] NeroVision 41 aa 01 34 00 4a 2a 2f
[00:16:52] NeroVision 00:16:47 #26 SCSI -1066 File Cdrdrv.cpp, Line 1434
[00:16:52] NeroVision SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x074E0000
[00:16:52] NeroVision Status: 0x04 (0x01, SCSI_ERR)
[00:16:52] NeroVision HA-Status 0x00 (0x00, OK)
[00:16:52] NeroVision TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
[00:16:52] NeroVision Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
[00:16:52] NeroVision Sense Code: 0x24
[00:16:52] NeroVision Sense Qual: 0x00
[00:16:52] NeroVision CDB Data: 0x2A 0x00 0x00 0x02 0x1A 0x99 0x00 0x00 0x1B 0x00 0x00 0x00
[00:16:52] NeroVision Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
[00:16:52] NeroVision 0x00 0x00 0x00 0x00 0x24 0x00
[00:16:52] NeroVision 00:16:47 #27 CDR -1066 File Writer.cpp, Line 311
[00:16:52] NeroVision Invalid field in command
[00:16:52] NeroVision 00:16:47 #28 Text 0 File ThreadedTransfer.cpp, Line 228
[00:16:52] NeroVision all writers idle, stopping conversion
[00:16:52] NeroVision 00:16:47 #29 Text 0 File ThreadedTransfer.cpp, Line 222
[00:16:52] NeroVision conversion idle, stopping reader
[00:16:52] NeroVision 00:16:47 #30 Phase 38 File APIProgress.cpp, Line 276
[00:16:52] NeroVision Burn process failed at 32x (4,800 KB/s)
[00:16:52] NeroVision Existing drivers:
[00:16:52] NeroVision Registry Keys:
[00:16:52] NeroVision HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
[00:16:53] GCHW Node added: Microsoft Kernel Wave Audio Mixer
I've never had this problem with Nerovision Express 2. The main program I'm using is Nero OEM, I wonder if that's got anything to do with it.
Also, the picture on the tv screen seems to be stretched out; I use a UK TV. I've encoded the avis with Tmpenc, and selected the function of Full Screen (aspect ratio 1). I've selected NTSC, PAL, UK PAL, but it's still stretched out.
Please help, thanks.
Results 1 to 1 of 1
NeroVision Express 3 does not have chapter buttons
By Brent G. in forum Authoring (DVD)Replies: 1Last Post: 8th Aug 2008, 23:45 -
DVD-RW VRO to DVD in NeroVision Express problem
By ecc in forum DVD RippingReplies: 1Last Post: 30th Jul 2008, 00:17 -
Is somebody a NeroVision Express expert?
By jeanpave in forum Authoring (DVD)Replies: 12Last Post: 15th Sep 2007, 22:42 -
NeroVision Express 3SE: Return to the main menu?
By frankieg in forum Authoring (DVD)Replies: 2Last Post: 11th Jul 2007, 10:31 -
main menu music, nerovision express 3
By Reggie6966 in forum Authoring (DVD)Replies: 4Last Post: 10th Jun 2007, 07:00
