I have a Geforce 4 ti 4200 with tv out video card. i would like to hook it up to my TV but I have one problem. I can't get the svideo cable to connect to my video card. It has a multi pin connector and s-vid only has 4. I have tried to connect it anyway but it won't fit. Do I need a converter? If so what kind and where is the best place to get one? I can't find my manual or a online one to help.
Thanks in advance.
Rob ( NS Canada)
There's usually a dongle that connects to the card. The socket on the card will look similar to a s-video socket but it's not.
Simialr to this, there's a pic here at the bottom of the page for a MSI ti4200
http://www.hardcoreware.net/reviews/review-102-2.htm -
Didn't come with one. know where i can get one?
I checked around and they don't supply them anymore
insert it this way
-- or
i got exactly same problem got 4 pin svideo cable and multi-pin geforce s-video output. i just turn the cable until the big plastic pin fits to the big whole in my gforce s-video output.
i got black and white display though...tell me when you got colored display output in your tvhacking the Net using typewriter :D -
Would not fit no matter what way I tried. I have to get a VIVO Adapter either at the local radio shack or on e-bay. They are cheap though.
Thx
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
